Rubber Renewer?? Need to revitalize Carb Boots
- mox369
09 Mar 2009 09:54 - 09 Mar 2009 09:55
Hey Guys, i cant get my carbs back on cuz the rubber boots are way to stiff, i saw on another forum that this guy used a rubber renewer, but cant find the stuff anywhere, any suggestions?? This would also be good for all the other rubber parts on the bike when i take it apart. Any links or suggestions of things to use would be great!!
Here is the pic of what the guy on the other forum used, cant get ahold of him to find out where he got it.
83 KZ 1100 Shaft Drive
Last edit: 09 Mar 2009 09:55 by mox369.
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Rubber Renewer?? Need to revitalize Carb Boots
09 Mar 2009 10:22
My gut feeling...sounds like snake oil. I don't know what bike you are working on but if new boots are available, order them. I just removed a set of carbs from a 78 650 on Saturday, the boots were so hard I ended up cutting them off with a hacksaw. Compared to the new soft rubber boots I have is like night and day. I'm as cheap as they come but for $10 a carb it is money well spent. Just my $.02 worth.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Mcdroid
- Gone Kwackers
09 Mar 2009 10:34
How much time do you have? When I am taking a bike apart and I know it will be a while before I reassemble it, I'll take all those rubber bits and drop them in a ziplock bag and liberally apply original 'ArmorAll' and let them soak. The ArmorAll will 'soften' up old rubber (not restore it, but soften it) so you can use it another time or two. However, if you really want to do it 'right' then follow Andy's (The Gringo) advice and replace those boots w/new.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
09 Mar 2009 11:02
mox369 wrote:
Am guessing NAPA's version of Armoral.
See page 33 of NASA website > BodyPro Rubber Conditioner on page 33
Sometimes heating with a hair dryer temporarily softens the old hardened rubber air intake hoses. Then work fast! :lol:
Good Luck!
Good Luck!
- mox369
09 Mar 2009 12:12
$10 per boot? or for the set of boots? Where can i find these at? ebay or other retailer?? Thanks guys, i am finally finding some time to start workin on this bike and have no clue what i am doing, should be fun!
- The Gringo
09 Mar 2009 13:02
They run about $10 per boot give or take. Check with Jeff at Z-1 Ent. he usually has the best prices and his service is second to none.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- bountyhunter
09 Mar 2009 14:23
There is a liquid called something like "Rubbernue" or similar which does strip off the hardened surface rubber. It was designed for rubber drive belts and idler wheels in audio equipment. I used to take a belt and drop it in the bottle and let it soak, then gently wipe off the belt. It will remove hardened rubber, but nothing on earth will reverse the aging process the rubber has experienced.
- bountyhunter
09 Mar 2009 14:25
mox369 wrote:
I can help you there: soak them in some very hot water for a while and that will soften them up. You can use a small amount of dishwashing liquid to make them slippery on the necessary surfaces.
09 Mar 2009 15:33
For example, here are the air intake hoses for 1976 KZ900-B1 LTD available at Z1 Enterprises.
Click here > Yes, Here!
Good Luck!
Good Luck!
- Jeff.Saunders
09 Mar 2009 15:48
I like a product called 303 Rubber Protectant. When I pull rubber parts off a bike, I spray them with this stuff and seal them in a zip-loc plastic page. While nothing will repair aging damage, this 303 product helps keep rubber in good shape.
www.303products.com/tech/index.cfm?fusea...splay&Product_ID=428
You can usually find this stuff at auto parts store and even Ace hardware.
www.z1enterprises.com
Z1 Ent on Facebook,
- Old Man Rock
09 Mar 2009 16:16
I'm with Gringo on this one...
Buy new ones for rejuventaor just won't do nor will it provide new like condtion for the intake manifolds to properaly seal for ideal/desired/optimum performance in your vacuum/tuning/operations of your carbs....
@ $10 a peice that's $40 plus shipping so lets say $50...
That's 7-8 fast food lunches any longer... If you're a smoker, that's 7 packs of Marlboro's, if you're into good beer, that's 6-6 packs of Fat tire Beer, if you're into fine wine, that's 3-4 bottles, pending the wine of choice that's not even one bottle of fine wine.....
See the pattern here....
Your carbs are such an extremely important part of your motors pereformance, don't go cheap here on this one...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kano
- Not Another Bloody Limey!
09 Mar 2009 16:24
as a father of 4 daughters by 3 different women in 2 different countries i can say don't use old rubbers buy some new ones from jeff! @ z1e.
