KZ440 Carburetor Problems
- turbotom
22 Feb 2009 20:37
New to the KZ world here, just posted in the new members section. I am looking for some help with getting my bike started, it is a 1980 KZ440. I inspected and cleaned the carburetor, but I am still not getting fuel. I can see through all the jets so I know they are not plugged, with the exception of the pilot jet in its passage which I assume is due to the passage taking a turn. I noticed that the vacuum hose on the right side carburetor has been plugged with a bolt by the previous owner, and I do not see a hole at all in one of the carburetor's pilot airscrew. The bike has new gas, new oil, a clean filter, and will fire up for a second with starter fluid in the carburetor. Is there something I am overlooking? It seems like it should be an easy fix. I appreciate any help. Thank you,
Tom
Tom
- OKC_Kent
Re: KZ440 Carburetor Problems
23 Feb 2009 09:46
Are you getting gas out of the petcock?
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- turbotom
23 Feb 2009 10:13 - 23 Feb 2009 10:15
OKC_Kent wrote:
Yes, I drained the old gas out before putting new gas in, so the petcock is working. I feel that the problem may be the pilot jet or the plugged vacuum hose. If I look into the pilot jet, should I be able to clearly see through? Should the vacuum hose on the right side carburetor be plugged? Thank you.Are you getting gas out of the petcock?
Last edit: 23 Feb 2009 10:15 by turbotom.
- nads.com
23 Feb 2009 13:22 - 23 Feb 2009 13:23
If the bowls do have gas and it won't start, take off the carbs and spray carb cleaner and air through the passages. look into the throats close to where the throttle blades close, there are some holes there. When carb cleaner comes out those holes when sprayed into the pilot jets OYOUGOTIT! Take the pilot jets out and clean them good. The air box must be on for the slides rise all the way to the top for full throttle. However! I will not wish you good luck because i know will have it! I tuned one of those up awhile back and detailed it for a guy whos daughter is autistic, and the magic is flowing through to you. :)If gas isn't flowing out of the petcock, turn the lever to prime.
Last edit: 23 Feb 2009 13:23 by nads.com.
- turbotom
23 Feb 2009 16:27
Cleaned the carbs again, removed the pilot jets and cleaned them good, I am still not getting anything. Could this be a timing issue? It does not make sense because the bike will try to fire up with starter fluid, but I really don't see how the carb can still be the problem.
- KZQ
- Administrator
23 Feb 2009 17:30
I'm no carb guru, but is there a brass pickup tube on your carbs that extends down into the bowls? If so there's a passage between the bowl and the sump. That passage and that brass tube are frequently plugged when a bike sets long enough for the gas to evaporate.
Hope that helps.
KZCSI
Hope that helps.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- nads.com
23 Feb 2009 22:07
sorry guy forgot about the brass tube -that's the problem. It might take alot of carb cleaner and air to unblock it, but it will blow through just dont give up on it. When it does finally clear make sure its GOOD and clear, it might let air through but still be partially blocked, listen to the sound of the air. Eventually it will unblock all the way. These are some of the toughest blocks i've seen on carbs, but it isn't that hard to clear it. I hate when i forget something, now he had to do it all over again for noi:angry:
- turbotom
24 Feb 2009 06:39
nads.com wrote:
I have a Haynes manual that I am trying to locate this brass tube with, but I can't seem to find it. Where exactly is it located?
- wiredgeorge
24 Feb 2009 06:39
The KZ440 uses Keihin CV series carburetors that have a real choke butterfly and therefor have no brass pickup tube which is there to pick up gas on carbs equipped with enrichener (choke plunger) circuits.
- turbotom
24 Feb 2009 08:10
wiredgeorge wrote:
Well that's unfortunate, it sounded like that brass pickup tube was the problem. Any other ideas?
24 Feb 2009 08:40 - 24 Feb 2009 08:41
Perhaps a compression issue and not a carb issue.
Last edit: 24 Feb 2009 08:41 by Patton.
- turbotom
24 Feb 2009 10:03
Patton wrote:
The bike would not start before the carb cleaning. I will have to check the compression, although the bike will fire up for a quick second with starter fluid sprayed into the carbs. This leads me to believe that it is not a compression issue, but a fuel delivery issue. Thank you for the suggestion.
Would the engine start up and run before the carb cleaning?
