Cleaning the inside of Fuel Tank
- tkaser
26 Feb 2006 15:17
I have read some of the different posts on cleaning with the battery charger/salt water process and I have seen some on a solution of berrymans, also taking the tank to a radiator shop and having it dipped.....So my question is what is the best solution? My tank has had the paint removed and now I am ready to take care of the surface rust on the inside.
Thanks in advance.
tkaser
Thanks in advance.
tkaser
- RetroRiceRocketRider
Re: Cleaning the inside of Fuel Tank
26 Feb 2006 15:27
If you don't mind the mess, smell and time it takes to do it yourself, it can be a good "learning" experience.
Just make sure to follow the directions of whatever brand product you use completely.
And also make sure you have adequate ventilation. Some of the products can turn a simple chemical buzz into a nightmare! :ohmy:
Since you already have the paint removed, it would be easier to just have a radiator shop do it.
No mess, and it only takes a few of days (depending on how busy the shop you use is) to complete.
I had my tank cleaned out and lined for only $45, and had it back in 2 days.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- ejshotgun
26 Feb 2006 18:40
Check out this thread from the archives...
Clean tank
This was the first one that came up I know I've looked at others.
But like Retro said since it's already stripped and if you got the money I'd have it done professionally.
Good Luck!
Clean tank
Good Luck!
- KZQ
- Administrator
27 Feb 2006 05:38
Hey tkaser,
Have you read my article on rusty tanks? If not check out the articles section.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- tkaser
27 Feb 2006 08:07
Well I really appreciate the feedback thus far. I got up this morning and called a few radiator shops in the area (St.Pete Florida) Tommy's was the only one I could find that still boiled and coated, so I went down and dropped off my tank. They tell me they will boil it and then use red kote to protect the inside. I was quoted around 70 bucks. I figure for the money and time it will be worth it.
tkaser
tkaser
- OKC_Kent
27 Feb 2006 08:41
That seems like a lot of money to me, but then I'm always looking for the cheaper way out. I don't have as much coin as the next rider.
Did this tank leak at all? If it did I guess $70 is ok to get it coated, but even that is something you can do cheaper. I would have flushed it myself for 2.98 before dropping $70 tho...
Heres my article in the filebase about how I cleaned my tank
kzrider.com/component/option,com_docman/...ls/gid,248/Itemid,5/
Cashion, OK
78 KZ650 B2 85,000+ miles
- tkaser
27 Feb 2006 09:46
Yes I certainly agree 70 bucks is quite a bit of coin, but this isn't something I really wanted to attempt on my own. I know I could have done it however there are something's I would rather a professional do. LOL As I have stated before, there are a lot of great ideas and many people have there own methods, but at this point I felt it would be wise to go this route.
Thanks again to all who have inputted.
tkaser
tkaser
- bemoore
27 Feb 2006 11:00
How are you all disposing of the remaining chemicals? My problem with most of these procedures is that they leave behind a quantity of chemicals I'm stuck with and can't get rid of.
77 KZ650C1 w/Kerker 4-1
- wiredgeorge
27 Feb 2006 11:47
If the tank is mildly rusted on the inside, use a solution of phosphoric acid. This acid is what professional painters use to prep metal for painting. It not only will remove the rust but kill it but you have to fill the tank with gas quickly after flushing to avoid more surface rust. The Berrymans is a waste of time. This stuff won't touch rust. I have personally tried finding a radiator shop that "dips" tanks to kill rust and can't find one. They all cut them first or at least they cut radiators.
- OKC_Kent
27 Feb 2006 11:48
Phosphoric acid (Tile & Grout cleaner) is very mild & can be diluted with water. I can't see where flushing it down a drain with plenty of water would hurt anything. Berrymans isn't intended to be a rust remover, it's a carb cleaner. If you use Electrolysis then that mixture is not hazardous and can be dumped on your lawn.
Post edited by: OKC_Kent, at: 2006/02/27 14:54
Cashion, OK
- bemoore
27 Feb 2006 12:15
OKC_Kent wrote:
OK. The tile & grout cleaner can obviously be flushed down the drain (I should have realized that one), but what about old gas, kerosene, acetone, and new gas (used to flush out kerosene and/or acetone). I realize that regardless of the method, I'll have to find something to do with the old gas.
Phosphoric acid (Tile & Grout cleaner) is very mild & can be diluted with water. I can't see where flushing it down a drain with plenty of water would hurt anything. Berrymans isn't intended to be a rust remover, it's a carb cleaner. If you use Electrolysis then that mixture is not hazardous and can be dumped on your lawn.<br><br>Post edited by: OKC_Kent, at: 2006/02/27 14:54
- OKC_Kent
27 Feb 2006 12:42
I have mixed small quantities of old gas with fresh new gas and put that in my lawnmower.
I don't know what I would do with acetone, probably check the MSDS sheets on that one.
Kerosene, I'd find a way to burn it off:whistle:
Cashion, OK
