No fuel problem
- bigpappab
08 Feb 2009 11:58 #262946
by bigpappab
No fuel problem was created by bigpappab
82 KZ1100 A2 model
Swapped to a Pingle petcock, carbs recently got a jet kit and 4 air filter pods (I did none of the carb stuff..previous owner).
Fuel flows freely from petcock down to the "T" fitting on the carbs but am getting nothing to the plugs..no start. I noticed there are 2 rubber vacuum lines coming from 2 of the carbs that go to a "T" but the end of the line goes nowhere, just hanging there. My Clymer manual shows nothing about where it is supposed to go.
Could this be part of my problem?...HELP!!
- trianglelaguna
- Thank you received: 235
08 Feb 2009 14:57 #262999
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic No fuel problem
waiting for someone to answer .... ...cv carbs knowledge folks????
BUMP....
BUMP....
1976 KZ900
2003 ZX12R
2007 FZ1000
- gane
- Thank you received: 1
08 Feb 2009 15:07 #263002
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic No fuel problem
Not familiar w/your bike but.two vac. lines t'd would suggest vacumne to the ega "gulp" valve for AIR system. luck G
- otakar
08 Feb 2009 15:08 #263003
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic No fuel problem
The two rubber lines are not vacuum, they are just float bole vents and "Just hang there" Something in the carburetors is not set up right. Will the bike kick if the choke is on?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bigpappab
08 Feb 2009 15:10 #263004
by bigpappab
Replied by bigpappab on topic No fuel problem
OK, just vents. I can deal with that.
Bike will not fire. Cranks like crazy but no fuel. I pulled and the plugs and they are dry as a bone
- otakar
08 Feb 2009 15:12 - 08 Feb 2009 15:17 #263006
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I apologize:blush: !!!!! They are vacuum lines. They go to a "T" which in turn goes to the air valve on top of the engine. "My Bad":blush: The valve has a vacuum switch in front of it specifically for this hose. It is the same valve that the two hoses go to from the top of your cam cover. But, I don't think that is your problem. This would just cause a lean condition but would not prevent the bike from starting. You said that you are getting gas to the float boles?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Feb 2009 15:17 by otakar.
- bigpappab
08 Feb 2009 15:24 #263010
by bigpappab
otakar wrote:You said that you are getting gas to the float boles?[/quote]
Well, at least there "Was" fuel in them. I just checked them enough to make sure they weren't clogged.
I'll go check...standby
- gane
08 Feb 2009 15:39 #263016
by gane
Stab in the dark.Since I'm not familiar w/ Pingle making a vac. petcock am guessing there are 3 vac. lines which need be blocked. Am guessing you have fuel in carbs.G
- bigpappab
08 Feb 2009 15:45 #263018
by bigpappab
Ok, I drained the bowls the turned the gas back on and they refill no problem.
Pingle does NOT make a vac model that I am aware of either. I have not blocked any lines either
- bigpappab
08 Feb 2009 15:48 #263020
by bigpappab
I got the bike back from the shop after the carb rebuild and jet kit and it ran great for about 10 miles. I had an electrical issue preventing the battery to charge. I replaced the rectifier, hopefully that fixes it.
I just started having this carb problem. I'm guessing there is something clogged somewhere? I didn't notice those 2 vacuum lines loose before so I thought this could have been a problem.
- otakar
08 Feb 2009 15:53 #263023
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
In this case, I would guess that the main jets are clogged from sitting. On vac carbs, if the main jets are clogged this will prevent fuel going anywhere els. This includes Idle jet or Fuel enriching/choke. You should at least take the carbs off and clean all the jet holes and port holes. Are you getting SPARK????:ohmy:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bigpappab
08 Feb 2009 15:56 #263026
by bigpappab
Yeah, got spark.
I REALLY didn't want to take the carbs off
