Anyone use yellow teflon tape?
  • RonKZ650
  • RonKZ650's Avatar
Re: Anyone use yellow teflon tape?
03 Feb 2009 10:54
#261916
What kind of petcock screws into an adapter plate? On that setup I think I'd use JB weld on the threads.
  • OKC_Kent
  • OKC_Kent's Avatar Topic Author
03 Feb 2009 11:15
#261922
See the picture farther back in the thread Ron. It's a manual petcock with reserve. If I JB weld the petcock to the plate, then I would need a way to seal the plate to the tank whenever I remove it. The adapter plate does not seal with an o-ring like the original petcock, so they supplied some blue colored sealer called Hylomar Blue. I priced that stuff and it is very expensive for a little tube. It's easier to seal the plate to the tank one time with the little package of sealer they gave me, and then I only replace the teflon tape when I need to remove the petcock.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • RonKZ650
  • RonKZ650's Avatar
03 Feb 2009 12:59
#261955
OK, I get it now :) I'm a little slow. Good luck.
  • eaglecrash2
  • eaglecrash2's Avatar
05 Feb 2009 19:24
#262430
That's exactly what I did when I replaced the leaky factory petcock with the manual pingel from Z1. Everything is working fine using white teflon tape.
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
