Anyone use yellow teflon tape?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Anyone use yellow teflon tape?
01 Feb 2009 04:29
#261348
rectorseal,not rectal seal !:unsure: :ohmy: :huh: :dry: :blink: :blush: :S :woohoo:
  • timebomb33
  • timebomb33's Avatar
01 Feb 2009 04:55
#261355
okay is some of that around in stead. because i'll take a case if it is. keep on the look-out for will you boy's thanks from the bottom.
I THINK MY POWERBAND BROKE
01 Feb 2009 06:16
#261382
[img] timebomb33 wrote:
... thanks from the bottom.
Here, try this! :laugh:
images.google.com/imgres?imgurl=http://w...0%26hl%3Den%26sa%3DN
  • timebomb33
01 Feb 2009 06:20 - 01 Feb 2009 06:21
#261387
man some of those people on there are just phucked. thanks any way butt not quite what i had in mind
Last edit: 01 Feb 2009 06:21 by timebomb33.
  • OKC_Kent
  • OKC_Kent's Avatar Topic Author
01 Feb 2009 06:21 - 01 Feb 2009 06:24
#261388
I used white tape here:
It actually was just mushy and seemed ready to leak. When I took off the petcock the two screws holding the faceplate were loose and the rubber diaphragm inside was damaged. That is where it was leaking. I've got the replacement part from Z1. I'm going to try that Permatex on the threads. I just remembered something, a sealer called Hylomar Blue that someone mentioned was good for fuel use.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Last edit: 01 Feb 2009 06:24 by OKC_Kent.
  • timebomb33
01 Feb 2009 06:24
#261390
guys i have noticed that over the last few years the additives that the fuel companies are putting in there product is just playing hell with vaccum petcocks so that is why i always replace them with manual ones like the pingel
  • wiredgeorge
  • wiredgeorge's Avatar
02 Feb 2009 08:00
#261698
I thought fuel pipes on the carburetors were being discussed. I use regular teflon tape on the petcock where it screws into the adapter plate. ResTape Yellow Gas Thread-Seal Yellow Tape is good to use with gasoline or gasohol according to their product fact sheet. I haven't tried it but may get some and give it a try.
www.restek.com/restek/images/external/308-02-002.pdf
  • trianglelaguna
  • trianglelaguna's Avatar
02 Feb 2009 08:16 - 02 Feb 2009 08:21
#261701
yellow tef tape is common here in cali in folks tool boxes and my earlier post and refs was for consruction ....not motorcycles...rector seal or tfe paste is also what i use now for my occasional jobs with gas..water(not on bikes) ... it saves having to wrap threads and can get aroung tight to the wall jobs better than a role a tape...it also conforms to the threads and bends and shapes of stuff nice..i use it on both pieces prior to assmb......ect...i get it at home depot for 6.00 and will last me a lifetime for radom use
giving guys a good will heads up tip is hard sometimes on this site...even if its just to hear what others think of your suggestion ..some lack tact in correcting peoples blunders ...i give public group tours for fun at pt.sur state park and light station....when i hear info from another VOLUNTEER that is iffy i don't cut em a new one... and the folks that override people all the time just to be right and let every one know it....are no fun and the public totally pull me aside later in the tour and comment about the jerk....we call em sharpshooters...and try and pick weekends to sign up when they are not signed up to help on the tours so we can have fun and share our hobby with cool people....my 2 cents...peace
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 02 Feb 2009 08:21 by trianglelaguna.
  • OKC_Kent
02 Feb 2009 08:19
#261702
Thanks for all the help. I'll be hunting down some yellow tape.
Kent
Oklahoma City, OK
  • trianglelaguna
02 Feb 2009 08:23
#261703
Kent
plumbing section any hardware store 2 bucks or under...ask the counter guy....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
  • sean5775
  • sean5775's Avatar
02 Feb 2009 12:05
#261733
Teflon thread tape is only suitable for NPT (pipe or tapered threads)
North american color codes are as follows, other parts of the world use different colors. Yellow is always for natural gas.
White tape is a general purpose tape most often used for plumbing.
Yellow is for natural gas, almost the exact same thing as white except that it is rated and tested for use on natural gas lines in enclosed spaces. Many gas inspectors will not allow the use of any other teflon tape.
Green tape is used for oxygen, both breathing oxygen systems and say an oxy-acetylene cutting torch. Same as gas tape it is rated and tested for oxygen use.
Red tape is used on high temperature lines, usually steam lines
A hard to find blue tape is used for potable water lines EX - in a camper.
Thats what I know from my work experiences... I am a Journeyman gas fitter.
1972 Kawasaki H2-750 Triple Mach IV
1976 Kawasaki KZ900 A4
1981 Kawasaki KZ440 LTD
1981 Kawasaki KZ750LTD-4
1983 Suzuki GS650 Tempter
1981 Yamaha Virago XV920
  • trianglelaguna
02 Feb 2009 13:04
#261737
1976 KZ900
2003 ZX12R
2007 FZ1000
