- Thank you received: 20
Anyone use yellow teflon tape?
- OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- PLUMMEN
- Thank you received: 104
- RonKZ650
- Thank you received: 240
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- wiredgeorge
We install the correct orings on fittings with orings OR recoat the fittings that are clad in rubber. This process in itself will stop leaks. We use tape to keep the fittings tight in their sockets because it is pivoting that wears either the orings or rubber cladding and either will them eventually fail.
I have never heard of yellow tape and would probably try some if not cost prohibitive and was readily available. There are sooooo many gurus giving advice on the internet that I have learned to be conservative when trying advice as a lot of the stuff that comes from a guru isn't really great advice. They did a mod of some sort on ONE application and it held together and then if they are a real guru, will sound thoroughly reasonable and knowledgeable and everyone will start taking the tip as gospel. The yellow teflon tape kind of sounds like this sort of deal but it is worth trying if you can find this stuff.
- Thank you received: 2098
The o-ring that's squeezed between the two-way nut when tightening a manual petcock to the tank is supposed to prevent leakage at that juncture, and provides a good leak-free seal on my bikes. Am thinking the o-ring design provides all the sealing necessary, that fuel doesn't contact the threads, and that these threads aren't relied on to themselves seal against fuel leakage.
While certainly no substitute for correct o-ring fitment, Permatex 56521 high performance thread sealant is touted for use on fuel fittings where the threads themselves are relied on to seal against leakage.
Permatex 56521
Am guessing it might be of some benefit on the screw threads attaching a vacuum operated petcock to the fuel tank where gasoline contacts the threads. But usually a washer between screw head and petcock serves the sealing duties.
Good Luck!
- OKC_Kent
Forum post:
Per ASTM (American Society of Testing & Materials) Standards we must use a thread sealant on all NPT (National Pipe Taper) Threads & fittings. The type of thread sealant is selected for compatibility with the material that the pipe will be conveying. In residential service the use of NPT joints is normally limited to water, natural gas, propane gas, #1 & #2 heating oils and occasionally low pressure steam, refrigerants or high-pressure air in a shop compressor system.
TEFLON TAPE:
When PTFE (Teflon) tape first became available they only made it in the common single density type, which we commonly find in the hardware and home supply stores. Later they began making a double density version, which was twice as thick. Many state and local codes then adopted the double density type as mandatory when making connections for natural gas however since both products were the same color (white) it was difficult for inspectors to be sure which product had been used. PTFE tape is now made in numerous varieties and they have issued a color standard to determine which type should be used.
WHITE-Single density- should only be used on NPT threads up to 3/8 inch.
YELLOW- Double Density- yellow double density is often labeled as "Gas type"
RED-Triple Density: (Note-the container is red but the tape itself appears as a pale pink color). Presently required on all joints ½" diameter or greater.
GREEN- Oil Free PTFE tape- Required for use on all lines conveying oxygen (I.E. –medical oxygen or welding oxygen lines).
COPPER COLOR- contains granules of copper and is to be used as a thread lubricant but is not approved as a thread sealant. (Generally it is used as a thread lubricant on bolts or pipe threads for mechanical applications where no physical seal is required.)
PTFE tape is only approved as a thread seal when applied correctly. To apply you begin at the end of the pipe and wrap the tape under tension in the direction of the thread turns. Each successive layer should overlap the previous layer by ½ to 2/3 and continue wrapping until the entire threaded portion of the pipe is covered. (Minimum of 3 full turns).
PIPE DOPE:
When looking for pipe dope in the hardware or home supply store we commonly find two types, a tube of dark gray paste labeled "Pipe dope" and tubes or small bottles of white "Teflon Pipe Dope". When selecting the pipe dope check the fine print very carefully to insure the product is listed as approved for the application you intend to use it for as some of these products have a very limited range of applications. As a rule the Teflon pipe dope will have the broadest range of applications and will normally meet all requirements that would typically be found in a residential environment. (My personal reservation with Teflon pipe dope is that it is extremely messy to work with.)
WHICH TO USE?
Providing the Teflon tape or pipe dope is approved for the type of material you intend to convey in the pipe the choice of tape or dope is then a matter of personal preference. Although there is no hard and fast rule that I am aware of, as a rule most plumbers prefer to use pipe dope on all permanent pipe joints, which are pipe joints which would normally be expected to last the life of the structure whereas Teflon tape is often the material of choice when attaching the end use trim out items such as threaded angle stop valves or shower arms and shower heads or in any exposed location where pipe dope might prove unsightly.
As a rule I never make a product endorsement but in the case or pipe dope I will make an exception to that rule.
While there is a number of universal pipe dopes on the market in my opinion the product that is most widely accepted by plumbers, pipe fitters, HVAC techs and electricians, as the standard is a product called "RectorSeal".
RectorSeal is made in both a hardening and non-hardening formula. (The advantage of the non-hardening formula is that the product will not dry out between uses so a small ½ pint container would meet the needs of a homeowner for years to come.)
While other pipe dopes are may be listed for a broad range of applications RectorSeal is listed as approved for but not limited to, Potable water, non-potable water, DWV, Natural Gas, propane, fuel oils (#1 through heavy bunker oils), gasoline, kerosene, diesel fuel, motor oils, lubricants, aviation fuel, jet fuel, high & low pressure air, low pressure steam, high pressure steam, most refrigerants, numerous industrial chemicals, most agricultural fertilizers and electrical conduits in both above grade and direct burial applications.
Although RectorSeal is seldom seen in a hardware or home supply store it can be found in almost all plumbing supply houses, HVAC supply houses and electrical supply houses. In fact, in most trade supply houses if you ask for pipe dope this is the product they will hand you unless you specify another brand.
Oklahoma City, OK
- RonKZ650
- H2RICK
- Is this a fun bike, or what!!!
and even some that are non-threaded.
Teflon tape, as per one post above, requires that the proper grade/type be used....otherwise failure is sure to follow.
My .02....
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- PLUMMEN
i believe he was referring to natural gas,not gasoline!:laugh:I personally wouldn't do what Ron is telling you to do as I don't think he is understanding how you are using the tape Kent. I wrap all my fittings with regular white teflon tape and it lasts indefinitely. The reason your tape failed was that it was there to stop gas from seeping out.
- PLUMMEN
i use rectorseal T plus 2 or something like that on water and gas lines never had a problem with it,i buy it at fergusons plumbing supplyWell I researched a bit and Patton is right, yellow is intended for gas lines, as in Natural Gas. The pink stuff Plummen has is mentioned for 1/2" and above fittings. What's interesting is the end of the other forum post, where Rectorseal is said to be good around gas/fuel. Maybe I'll find some of that and try it.
Forum post:
TEFLON TAPE:
PIPE DOPE:
WHICH TO USE?
- timebomb33
I THINK MY POWERBAND BROKE
