- Thank you received: 2829
SO FRUSTRATED - Run away idle
18 Jan 2009 18:49 #258693
by 650ed
Replied by 650ed on topic SO FRUSTRATED - Run away idle
One other thought. Make sure your choke is working properly.
- bigkzfan
- if grandpa had tits he"d be grandma, if
- Thank you received: 1
20 Jan 2009 19:42 #259101
by bigkzfan
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
Replied by bigkzfan on topic SO FRUSTRATED - Run away idle
sound like an issue my friend had with his xs100 with the run away idle it wound up being the linkage going thru all the carbs was slightly bent...it took him a year and wasted money throwing parts at it before he was ever able to ride it, it had us both stumped..
- bigkzfan
20 Jan 2009 19:47 #259102
by bigkzfan
btw he wound up taking it to a shop and they found the problem...freakin thing runs great now:(
- WBPDX
- 1983 KZ750 H3
20 Jan 2009 19:48 #259103
by WBPDX
Replied by WBPDX on topic SO FRUSTRATED - Run away idle
Actually, I am starting to suspect the choke as well. I've had very little time to mess with it, I am afraid the garage is just too cold, but I noticed tonight that the sounds from fliping the choke back and forth don't sound right all the time...
I'll quickly cover your suggestions:
- Tried WD40, might have found a link on #1, but the idle is so erratic it is hard to tell.
- Slides ARE moving, cv carbs, diaphrams are all 100% perfect, like new.
- Airbox and filter are there (I'll keep mentioning it until people stop aasking)
- Tried blocking airflow from the start, doesn't seem to make much of a difference, this makes me think it must be drawing air in from elsewhere.
- Checked the linkage\synch and everything is moving properly; I'm hesitant to mess with it too much without a synch gauge.
I'm thinking choke; I'm going to try and check that out tomorrow, and if it is okay, I'll try carb holders, and then go from there...
Of note: after getting WD40 everywhere, it did start to run a little better, so maybe the oil snuck in and slightly lubricated either a slide or one of the choke butterflys? I'm not sure, but it is worth noting.
- Kawickrice
- Thank you received: 18
20 Jan 2009 19:56 #259105
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic SO FRUSTRATED - Run away idle
If wd 40 smoothed it out try carb cleaner (more volatile than wd) use the little straw and spray small amounts. you will hear the idle swing.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- wiredgeorge
21 Jan 2009 06:36 #259164
by wiredgeorge
Replied by wiredgeorge on topic SO FRUSTRATED - Run away idle
Replace the carb holders. Never Never try to fix cracks. If there are cracks, they are too hard to seal correctly anyway.
- JMKZHI
- Thank you received: 48
21 Jan 2009 07:56 - 16 Jun 2009 19:33 #259171
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 16 Jun 2009 19:33 by JMKZHI.
- WBPDX
- 1983 KZ750 H3
21 Jan 2009 19:18 #259275
by WBPDX
Okay, so just to clarify, the spark is better than Okay, it is extremely strong. It throws fat blue sparks in a moderately well lit garage. I have also checked all the connections, and the only one remotely loose, I have re-done.
Tonight I found the choke is perfectly fine.
I'm betting everything on the carb holders I guess...
To clarify the cracks were very small, just under the bolt caps, and I didn't expect to ride the bike with RTV over the cracks; it was simply to see if it made a difference (which it didn't.)
- WBPDX
- 1983 KZ750 H3
21 Jan 2009 19:20 #259276
by WBPDX
Also, I am not going to spray carb cleaner because:
A- It breaks down plastics\rubber
B- It will eat the engine paint
C- It is very flammable, and the bike is 'stuck' in a small garage right now. I can't take any chances.
- timebomb33
- Thank you received: 10
21 Jan 2009 20:55 #259296
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic SO FRUSTRATED - Run away idle
ok if you don't want to use carb cleaner try a spray bottle full of water it wont allow it to rev up instaed it will kill the cylinder that is leaking my self if i'm trying to find an air leak fast there is no better product than ether or starting fluid as some people call it just keep your hand over the kill switch if the air leak is really bad with that product you will find the problem fast.
- Steveo
23 Jan 2009 09:24 #259610
by Steveo
1982 kz440A
Replied by Steveo on topic SO FRUSTRATED - Run away idle
I had the uncontrollable revving problem on my 440 a couple of years ago. The rubbber carb boots were cracked in a few places so I tried to seal them...no dice, I ended up buying new ones, it helped a lot. I feel your pain.
1982 kz440A
- WBPDX
- 1983 KZ750 H3
23 Jan 2009 21:37 - 23 Jan 2009 21:39 #259809
by WBPDX
So, I discovered a bad\questionable wire. The bike now has all new Accel wires, and brand new plugs to match.
No change, just smoother when running away.
I sprayed WD40, and then water all over everything again, trying to change a cylinder. No dice.
I thought maybe I was overflowing, as I saw what looked like gas inside the airbox, maybe like it had previously overflowed into the airbox, but things were a little 'moist' so I still considered it, even though using the clear tube method the float levels are dead on.
So I adjusted the floats to close slightly sooner (tighter?)
I carefully inspected all the boots\holders - NO problems. The cracks I mentioned earlier are very surface-level, don't go all the way through.
Now the bike is even worse, it just runs away instantly upon 'starting.'
I'm going crazy with this effing bike.
Last edit: 23 Jan 2009 21:39 by WBPDX.
