- Thank you received: 1
adjustments on a 200A info?
- gane
22 Jan 2009 19:37 #259502
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic adjustments on a 200A info?
Believe you found part of problem w/oil change. Leaking petcock/float valve/s allowed fuel to drain into crankcase.when eng. came up to temp fuel/in eng oil evaporated thru crankcase breather & into airbox. thus extreem rich cond. you probly also have as others surmise dirty pilot circuits. Luck g
- iamwhoiam151
22 Jan 2009 21:31 #259541
by iamwhoiam151
Replied by iamwhoiam151 on topic adjustments on a 200A info?
this link isnt working on my pos puter. but no i dont have one and been looking all over the net. thank you.
- Thank you received: 2098
23 Jan 2009 03:37 - 23 Jan 2009 03:40 #259564
by Patton
Replied by Patton on topic adjustments on a 200A info?
iamwhoiam151 wrote:
The link is correct. Is enough time being allowed for the long and large download? If using dial-up, click the link and come back tomorrow. :laugh:
When checking ignition timing, concentrate on just the F mark and aligning the F mark with the permanent case mark at low idle rpm. Ignore the T mark and ignore all other marks.
When using a strobe type timing light and blipping the throttle, should be able to watch the advancer in action as it moves back and forth.
Good Luck!
this link isnt working on my pos puter....
Good Luck!
Last edit: 23 Jan 2009 03:40 by Patton.
- iamwhoiam151
23 Jan 2009 07:32 #259584
by iamwhoiam151
I was able to finally open the service manual. I can't thank you enough.
