need float hight #'s having problem with 81 750ltd
- cott10r
- Motorcyclist for life!!!
2012 kawasaki concours 14
2014 suzuki gsxr 1000
2014 honda crf 250L
1983 kawasaki gpz 550
- Thank you received: 2098
FOUND IT!!!!!! now what do i do? the culprit is a crack in the tube that is in the float bowl itself, the brass tubing has a crack in it from top to bottom, thnks everybody for pointing me in the right direction
Some Options:
Solder;
JBWeld;
Shrink tubing;
Fit a snug fitting plastic hose over entire length of the crack.
Good Luck!
- bountyhunter
- Thank you received: 337
- cott10r
2014 honda crf 250L
... pet-cock has quit working but that looks like no big deal, 30 bucks and that will be fixed too. btw my fiance is looking for an old kawi now, any suggestions on a cool old kz, im thinking an old 440 sounds fun
What's the petcock issue?
- cott10r
What's the the petcock issue?
its a vacuum operated with on-pri-res settings, when i 1st got the bike it would not run fuel with the engine off (you know like its suppost to) but now it constantly runs fuel, the diaphram or an 0ring must of died in it.
2014 honda crf 250L
... pet-cock has quit working...30 bucks and that will be fixed too...its a vacuum operated with on-pri-res settings, when i 1st got the bike it would not run fuel with the engine off (you know like its suppost to) but now it constantly runs fuel, the diaphram or an 0ring must of died in it.
Z1E lists the petcock repair kit for $20.76
and diaphram alone for
$12.46
Enough crud and grit sometimes accumulates inside to prevent proper function.
Before purchasing any new parts, would remove, disassemble, and clean the existing petcock, as this might be all that's needed to restore its proper function.
Good Luck!
[Click on image to enlarge view]
- Link14
- Thank you received: 6
The great thing about the '79 400 was that it used the same carbs as the 82 750 so I already had some experience with them. Trying to work on my 900's VM26's is scary compared to how simple the CV34's are.
Good luck
- cott10r
As far as your fiance goes, a 400 or 440 is a great starter bike. My first bike was a 1979 kz400 Ltd and when I got my '82 kz750 Ltd it looked like big brother/little brother with almost the same shape and color schemes. You could have a his and hers set. :laugh:
Good luck
she already rides, i got her riding when we 1st started dating 5 years ago, we started her on a 250 honda nighthawk, then a 25o ninja, 500 ninja, zx-6r ninja & now she rides a suzuki gsx-r 750. she thinks these old bike's are neat, i used to have a 79 kz 400 & a 82 440ltd, she says she would like one of those now. im kicking myself now but 3 years ago i purchased a 79 or 80 (i cant remember now)400 and all i did was put in a new batt and she fired right up, i only gave a $100 for it.
2014 honda crf 250L
- Link14
