K&N Pod air filters?
- Jimbo302
06 Nov 2008 12:07
Anyone running these? I have only used something similar once before and I did have to re-jet with them.
I'm thinking about pulling the airbox on my 1976 KZ900LTD and swap to these pod filters instead. Pro's and Con's?
- sbulla
- 1980 KZ1000 LTD
Re: K&N Pod air filters?
06 Nov 2008 12:15
Jimbo302 wrote:
Uh oh!....you might as well have asked what kind of oil to use. There are some STRONG opinions on here both ways.
I'm running the stock airbox...though, a few days ago when I was trying to remove my carbs, I was seriously thinking about pods.
More experienced folks will chime in soon.
Sonny
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Bluemeanie
06 Nov 2008 13:17
Yes, having pods makes carb removal/installation about 100% easier. However, sometimes jetting can be a problem. What appears to work fine at idle or around town now is a problem on the freeway with side drafts, passing vehicles, etc. Some guys here have no problems, some do. Some guys have had side covers fly off with the now empty space behind it becoming a high pressure area, most have no problems. I personally use stock box with a K&N filter. The choice is yours...
- anarki650
06 Nov 2008 15:10
I'm running K&N pods after starting with a stock airbox and then running cheap Emgo pods for a couple years. I've been one of the lucky ones who hasn't had problems getting my jetting right, but I'm also one of the ones willing to pull carbs off 15 times to make adjustments to make sure it's right. If you go pods, spend the money for the K&N, they are infinitely better than the cheap ass Emgo or Uni filters and definitely worth it.
To get my carbs jetted correctly (77 kz650b1 with vm26 carbs from a Suzuki GS750 and Mac 4-1 with very minimal baffling) I am running 17.5 pilots, 117.5 mains, with the needles on the #4 clip. Pilot screws are about 1 1/8 turn out from snug and air screws are about 1 3/4 turns out. Starts on the second or third kick stone cold (38 degree morning after sitting for almost 2 weeks), warms up in less than 2 minutes on choke, idles great, no hesitation at any point of throttle, pulls like a scalded dog all the way up to 10,500 rpm. In other words, runs great.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
The following user(s) said Thank You: Nickstros399
- Locozuna
06 Nov 2008 15:14
Get some new rubber boots. Fold the boots over on themselves. This will give you an additional inch of clearance to get the carb rack back into the bike. Once the rack is in just unfold the boots over the carb throats. I guarantee you will not have an embolism. Getting the airbox out is a pain and re-installing it after becoming disillusioned with pods is another pain. After having pods I really love my airbox and my nice soft boots.
Others have different experiences. This is mine.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
The following user(s) said Thank You: old_kaw
- RonKZ650
06 Nov 2008 16:17
Like the guys said, there's strong opinions either way. I've gone 170,000 miles or so with stock box and similar with K&Ns so I'll relay my findings.
K&N:
Flows more air so after jetting possibly more HP.
Makes carb removal much easier.
Side winds and or rain? Bad news.
Rubber gets hard after a while and mounting gets goofy.
Gauze gets cruddy dirty quickly.
Flows more dirt than stock airbox.
Never lost a sidecover yet, so no problem there for me.
Carburetors no longer have support on the rear, so front intake boots fail regularly.
Stock:
No problem with wind or rain, supports back of carbs so intakes rarely fail.
Boots between airbox and carbs get hard and must be replaced regularly or carbs cannot be removed.
Better air filtration. (arguable, but my opinion). Reason I say this is many times I've removed carbs to clean and/or repair and K&N pod carbs always have gobs of visible crud built up in the carb, where stock doesn't.
My personal opinion is stock is far superior in the long term.
K&N:
Stock:
- keith1
06 Nov 2008 17:02
i put pods and jetted my kz1000ltd and i am happy with it....i got baseline numbers for jets and clip position from wired george and dont have any complaints....i dont know where the idea that you would be better off trying to shave a tigers ass
than put pods on a bike and jet it comes from...
there are other forums where you will hear 100% no.......k and n are a must....spend the cash...the emgos look great, but are garbage...mine are buried in my box of old parts in garage and they have about an hour on them......just my .02..keith
- guitargeek
06 Nov 2008 17:36
I have dual flange K&N pods, and have zero problems with side winds.
It takes me about one minute to pull my carbs.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- PLUMMEN
06 Nov 2008 18:05
stick with the stock airbox and stock style filter in it
- keith1
06 Nov 2008 18:21
guitargeek wrote:
i like those...i wonder if there is enough room for the dual fuel pipes i have? where did you purchase those? thanks.....keith
- guitargeek
06 Nov 2008 18:32
keith1 wrote:
eBay, but you can find them at K&N's site, search by dimension. www.knfilters.com/search/univ2.aspx?ID=S0015where did you purchase those? thanks.....keith
- franknsr
06 Nov 2008 19:32
Oooh, I think I have dual pod envy. I need a pair of those .
I'm running the cheap pods because the stock airbox will no longer fit on my bike, but I wish it did. The pods have their advantages but I figure the guys who designed these bikes were way smarter than I.
If you like to tinker, want to get a little more ooomph out of your bike and don't mind a bit of inconvenience, pods are nice. If you want trouble free riding stay stock - IMHO.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
