Rejet for 810/pods/pipes
- 77_650B1
17 Oct 2008 04:49 #242231
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Rejet for 810/pods/pipes was created by 77_650B1
Hey guys, do you think I should change the jets in my bs34's from a 95 Police? I'm going 810, with Mac pipes most likely, and pods. Should I just wait and see if I can get her running good with just air screw adjustment?
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- 77_650B1
31 Oct 2008 08:17 #244803
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic Rejet for 810/pods/pipes
Anyone?
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- jordan
- Thank you received: 5
31 Oct 2008 11:59 #244817
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic Rejet for 810/pods/pipes
if you have it running good for pods and a header, it should run just fine after the 810 kit.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- 77_650B1
31 Oct 2008 13:31 #244822
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
No, it's all stock now, I dont have the 34's on yet, I'm just wondering if I should think about rejetting right away after I do all that.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- jordan
31 Oct 2008 15:09 #244834
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Ya, I would try and get the jetting for the header/pods right before you do the 810 build. That way, you will have it set up right when you get it put back together. ALso, if you screw up in the rejetting before the build you will know its the jets and not engine problems you screwed up on during the build. Its just alot easier to narrow down the problems after the build when you know the carbs are set up right. I am not 100% certain, but i believe that on my 810 build i used 140/70 jets in my 34's with pods and a non-baffled header
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- 77_650B1
02 Nov 2008 08:02 #245135
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Right on, I wont actually be able to do that since I dont have 750 pistons, so its not really an option. I guess I'm gonna have to just try the jets that are in the carbs already, and try to get her smooth on the air screw. The stock jetting for a KZ1000 should have enough flow to supply an 810 though I'd imagine, even with the increased CR.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
08 Nov 2008 06:20 #246257
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Replied by Bdog on topic Rejet for 810/pods/pipes
The need to rejet should mainly depend on increasing air flow, not increasing compression ratio. When you add pods and a 4-1 pipe on a stock 650 you should rejet. When you increase CR you pay for increased octane fuel avoid detonation. And make sure your carb boots are in good shape (no cracks to introduce a lean condition) and the carbs are clean and properly working. I just pulled the pistons from an 810 kitted motor to find a severly pitted piston in the number one cylinder, and a new one is $135.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- 77_650B1
08 Nov 2008 10:18 #246295
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Yeah I know I'd have to rejet my stock carbs if I used them, but will I have to rejet bs34's which are from a kz1000? I'd figure there'd already be enough fuel supply in there for the 810.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
