Fuel Line diameter
- oldcuda68
Fuel Line diameter
13 Feb 2006 04:07
I need to know what size fuel line the 750/4 uses. I want to order some clear fuel line from Z1, but am unsure of the size. Any iformation appreciated.
Thanks,
Mark
Thanks,
Mark
1980 KZ750 LTD
1984 Honda GL1200 Interstate
Too many other toys to mention
- mariozappa
Re: Fuel Line diameter
13 Feb 2006 05:19
I'm pretty sure they were 1/4 inch I.D.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- hwms
- oldcuda68
13 Feb 2006 10:18
Thanks. That gives me an idea of what I need!
Mark
Mark
1980 KZ750 LTD
- Bluemeanie
15 Jan 2008 17:05
Is that original for 650's also? Carb inlet and petcock outlet same size? Dealer is no help, I prefer clear to see if gas is flowing or not. Thanks
- RonKZ650
15 Jan 2008 18:02
Yes it's 1/4" pretty much. Of course Kawasaki didn't use 1/4", they used 6.5mm ID on the 650 and 7.5mm ID on larger displacement like the KZ1000MKII. 1/4" will work for either of these. Trust me, you cannot buy metric fuel line anywhere in the entire world unless you order stock Kawasaki fuel line at $30 or so per 1/2ft. Z1 enterprises has thin wall 1/4"? That's what you want. Go to a dealer or autozone or any place similar you can get 1/4" fuel line, no problem, but it will be high pressure auto hose with 2/3" OD. No good for bikes.
- JMKZHI
Last edit: 03 Dec 2008 20:31 by JMKZHI.
- BSKZ650
16 Jan 2008 06:25
I get the metric size fuel line from either the yammy or honda shops close to me, they stock many sizes, they have been selling a blue tinted line which works well
77 ltd1000, current rider
76 kz900, just waiting
- Little B
20 Jan 2008 00:56
Yep, 1/4 fits great. I just got some from Z1 myself. It was tough to get on over the main fuel intake at the carbs but I found that if I slightly heated the end, that it would go on a little easier.
Careful though, if you heat it too much it sort of just bulges out around the top as you try to push it down.
If that happens to you, let it cool a bit and it should go on easier.
1981 KZ750-H2 LTD
- 1982KZ1100D1
20 Jan 2008 04:04
RonKZ650 wrote:
Why is it no good for bikes? Seems to work fine on mine. Do I need to change it?Go to a dealer or autozone or any place similar you can get 1/4" fuel line, no problem, but it will be high pressure auto hose with 2/3" OD. No good for bikes.
- RetroRiceRocketRider
20 Jan 2008 07:32
1982KZ1100D1 wrote:
Thinner walled fuel line allows for more flexibilty for routing purposes. And being more flexible, it's also less likely to pull a barbed fitting loose or off when you remove it. :S
RonKZ650 wrote:Why is it no good for bikes? Seems to work fine on mine. Do I need to change it?Go to a dealer or autozone or any place similar you can get 1/4" fuel line, no problem, but it will be high pressure auto hose with 2/3" OD. No good for bikes.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- 1982KZ1100D1
20 Jan 2008 07:46
Oh OK. I routed mine from the tank across all 4 carbs then sweeps around and under carbs to large in-line filter then to carbs so no tight bends.
