Fuel Line diameter
  • oldcuda68
  • oldcuda68's Avatar Topic Author
Fuel Line diameter
13 Feb 2006 04:07
#23489
I need to know what size fuel line the 750/4 uses. I want to order some clear fuel line from Z1, but am unsure of the size. Any iformation appreciated.
Thanks,
Mark
1980 KZ750 LTD
1984 Honda GL1200 Interstate
Too many other toys to mention
  • mariozappa
  • mariozappa's Avatar
Re: Fuel Line diameter
13 Feb 2006 05:19
#23492
I'm pretty sure they were 1/4 inch I.D.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • hwms
  • hwms's Avatar
13 Feb 2006 05:59
#23499
7 MM I.D.
  • oldcuda68
13 Feb 2006 10:18
#23533
Thanks. That gives me an idea of what I need!:)
Mark
1980 KZ750 LTD
  • Bluemeanie
  • Bluemeanie's Avatar
15 Jan 2008 17:05
#189478
Is that original for 650's also? Carb inlet and petcock outlet same size? Dealer is no help, I prefer clear to see if gas is flowing or not. Thanks :)
  • RonKZ650
  • RonKZ650's Avatar
15 Jan 2008 18:02
#189491
Yes it's 1/4" pretty much. Of course Kawasaki didn't use 1/4", they used 6.5mm ID on the 650 and 7.5mm ID on larger displacement like the KZ1000MKII. 1/4" will work for either of these. Trust me, you cannot buy metric fuel line anywhere in the entire world unless you order stock Kawasaki fuel line at $30 or so per 1/2ft. Z1 enterprises has thin wall 1/4"? That's what you want. Go to a dealer or autozone or any place similar you can get 1/4" fuel line, no problem, but it will be high pressure auto hose with 2/3" OD. No good for bikes.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
15 Jan 2008 18:32 - 03 Dec 2008 20:31
#189494
del
Last edit: 03 Dec 2008 20:31 by JMKZHI.
  • BSKZ650
  • BSKZ650's Avatar
16 Jan 2008 06:25
#189539
I get the metric size fuel line from either the yammy or honda shops close to me, they stock many sizes, they have been selling a blue tinted line which works well
77 ltd1000, current rider
76 kz900, just waiting
  • Little B
  • Little B's Avatar
20 Jan 2008 00:56
#190177
Yep, 1/4 fits great. I just got some from Z1 myself. It was tough to get on over the main fuel intake at the carbs but I found that if I slightly heated the end, that it would go on a little easier.
Careful though, if you heat it too much it sort of just bulges out around the top as you try to push it down. B) If that happens to you, let it cool a bit and it should go on easier.
1981 KZ750-H2 LTD
  • 1982KZ1100D1
  • 1982KZ1100D1's Avatar
20 Jan 2008 04:04
#190179
Why is it no good for bikes? Seems to work fine on mine. Do I need to change it?
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
20 Jan 2008 07:32
#190209
Thinner walled fuel line allows for more flexibilty for routing purposes. And being more flexible, it's also less likely to pull a barbed fitting loose or off when you remove it. :S
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • 1982KZ1100D1
20 Jan 2008 07:46
#190210
Oh OK. I routed mine from the tank across all 4 carbs then sweeps around and under carbs to large in-line filter then to carbs so no tight bends.;)
