- Thank you received: 16
Support brace for 29mm smoothbores
- mtkawboy
- FastKaw1
just thoughts and NOT set in stone...
In 35+ years of riding z1/kz's and most all have had
pod filters. I have NEVER had a problem with the
carb boots. (Yes) they do get old and crack/split
Is it because the carbs are hanging on them or is it
because they are made of hard rubber and live in a
hostile atmosphere? Heat+Gasolin I'd pick the latter.
If you get around 10 years on a set of carb boots i'd
say that not bad. All thing considered.
29's way haff as much as the old 28's. I have put 40K
on a Z1 with 29's and pods. and there was never a
problem with the boots sagging.
I always use SS hose clamps. They are wider then the
OEM clamps and support the carbs better.
All im saying is I don't worry about it.
XENU
- Bluemeanie
- Thank you received: 14
- Sandy
- Fly High,Tony
- Thank you received: 13
Are you sure that your carbs are in the boots all the way?:huh:
Loosen the clamps real good,and with your right foot on the rear brake,give them a good push from side to side.
They shouldn't sag.:huh:
1977 KZ1000 A-1
- wiredgeorge
- Z1109R Fin
Z1000R ´83...Slightly modified...
- mtkawboy
- RonKZ650
- Thank you received: 240
- zrex1100
- dnyce
- Z1109R Fin
wow-i think u guys are worrying way way too much.
Well, maybe but...I know the guy who dropped his RS34´s:huh: He rides about 30kkm / 19kmiles per year. Out here he´s known as the guru of light-weight Kawis. He owns a few of 550/650´s and a 750 Turbo.
IMO Better safe than sorry. Also I could tell you about a guy who drove into a pothole and cradded his Kerker K-canister in two....know him all too well:P Everything can and will happen. Thats the Murphys Law;)
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
