Carb Holder clamps
- SebRain77
- When in doubt, gas it!
20 Jun 2008 05:18 #221068
by SebRain77
Ever hit the pavement? I did, put that gear on!
1977 KZ 650C1 - First bike, ever! For sale - or not!?!?
2004 Z750 - More power than I'll ever need...
Gatineau, Qc, Canada eh!
Carb Holder clamps was created by SebRain77
Took off the carbs... bla bla bla... here is the thing. 2 of the screws from the carb holder clamps are stripped. could I just use regular hose clamps instead? I don't see why this would not work, but maybe you have suggestions or comments on this!?
Thanks!
Thanks!
- Bluemeanie
- Thank you received: 14
20 Jun 2008 05:48 #221072
by Bluemeanie
Replied by Bluemeanie on topic Carb Holder clamps
I still use my original clamps but... yes, you can use regulat hose clamps. Works fine..
- Thank you received: 2098
20 Jun 2008 05:57 - 20 Jun 2008 06:00 #221076
by Patton
Replied by Patton on topic Carb Holder clamps
Likely depends on design of the hose clamp and size of its mechanicals being compact enough to fit into the space allowed and being accessible for tightening.
On the large fours with manual slide Mikunis, its easier to use oem carb holder clamps and non-oem hose clamps on tubes from the airbox.
Also slightly easier access is afforded for tightening the inner airbox hose clamps by locating the clamp screw on top instead of on bottom, regardless of clamp type (oem or not).
Good Luck!
Good Luck!
Last edit: 20 Jun 2008 06:00 by Patton.
20 Jun 2008 06:04 - 20 Jun 2008 06:06 #221078
by Patton
Last edit: 20 Jun 2008 06:06 by Patton.
- RonKZ650
- Thank you received: 240
20 Jun 2008 07:04 #221090
by RonKZ650
Replied by RonKZ650 on topic Carb Holder clamps
Hose clamp will be a pain. Just buy the right parts @ $4.00 or so each. Yes $4.00 is a lot of money, more than a gallon of gas. Part # 92037-178
- Sandy
- Fly High,Tony
- Thank you received: 13
20 Jun 2008 07:18 #221091
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Carb Holder clamps
I agree with Ron.
A standard hose-clamp will be wider,and COULD be a pain to get a tight seal.
Not saying it WON'T work,cause obviously it has for Bluemeanie,but I would still try to get the original ones.
1977 KZ1000 A-1
- Stargate
20 Jun 2008 08:50 #221112
by Stargate
1981 KZ1000-K1 LTD
Original owner
Photos
Replied by Stargate on topic Carb Holder clamps
I've been using hose clamps on the manifold for years with the BS34 carbs and they work fine. I still use the original springs for the airbox side.
1981 KZ1000-K1 LTD
Original owner
Photos
- NiagaraZ
20 Jun 2008 08:59 #221113
by NiagaraZ
78 KZ650 D1
Replied by NiagaraZ on topic Carb Holder clamps
I put stainless steel hose clamps clamps on the engine side of the carbs, screws on the bottom and use the springs on the airbox side. No problems
78 KZ650 D1
- cmmman
20 Jun 2008 09:35 #221120
by cmmman
1977 KZ650B, modified.
Replied by cmmman on topic Carb Holder clamps
Maybe fix your original clamps with over size screw?
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
20 Jun 2008 10:44 #221128
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Carb Holder clamps
My clamps [Z500], involve a crosshead 6mm thread screwing into a captive nut.[captured by the clamp.] I removed the nut for cleaning/polishing, there are metal tabs each side that clamp the nut.They bend.
If yours are the same then you need a new nut.:silly:
1980 KZ500 B2
- wiredgeorge
20 Jun 2008 16:14 - 20 Jun 2008 16:16 #221204
by wiredgeorge
Replied by wiredgeorge on topic Carb Holder clamps
Sparky, almost all the screws used in the Kaw carb holders are M5 w/.8 pitch and are actually JIS standard screws... they are not SAE type phillips head but JIS and a different screwdriver (JIS #1) is needed to ensure you don't strip the heads... If any of you wonder why carb screws are usually all stripped, it is because a JIS screwdriver wasn't used.
As far as using hose clamps, yes you can use them but keep in mind they tend to cause the rubber to deform some if you overtighten them. I used hose clamps for a couple years when mounting VM24 carbs on my KZ900 test bike and had to take care. I eventually bought the correct clamps. You can't use the larger clamps meant for a VM26/28 because they are just on the large side... The OEM VM24 clamps work great and hold up better than the VM26/28 type.
Last edit: 20 Jun 2008 16:16 by wiredgeorge.
- SebRain77
20 Jun 2008 18:46 #221230
by SebRain77
Replied by SebRain77 on topic Carb Holder clamps
Hmmm, very different opinions here... i guess i'll try to find the right part at a dealer or something.... the "kid" at my local Kaw dealer had NO idea what I was looking for. then his supervisor came on the line and had no idea either. "I'll check and get back to you..." never did! I guess I'll find another dealer! I have the part number for the clamp, do the screws come with the clamp, or is it a different part number?
a JIS screwdriver, what the heck is that! I learn something new everyday!:laugh:
