- Thank you received: 1
KZ650 Petcock Fuel Line Elbow
- cfendrick
Let me know if there should be some seal or if I just need to use some silcon RTV or tape it or invest in one of those aftermarket ones.
- cfendrick
Here are the options.
1. Clean the elbow and Put JB Weld on the exposed section of the elbow's fitting, and then slide it the rest of the way in. Make sure there's a bead all of the way around the insertion point, and when it's dry, come back and file/sand the bead down to a small ridge so that it doesn't look like crap.
2. Tap new threads and buy a new 90 degree elbow with the same size threads. You can use tape, JB Weld or Liquid Solder on the threads.
3. Use Teflon tape. That way it's a lot easier than taking the line off if you want to pull the tank. Quick, but not necessarily a permanent fix.
4. Buy a new petcock
The elbow isn't supposed to come!
- rstnick
- Thank you received: 377
Just make sure you point the outlet where you want it to be while it's drying.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- JMKZHI
- Thank you received: 48
- JR
- Thank you received: 449
- Bluemeanie
- Thank you received: 14
- bill_wilcox100
- Thank you received: 5
Got a pic for me? Thanks.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- cfendrick
I ended up using Permatex Liquid Solder $1.99 at parts store and it holding good so far.
In the event that it leaks 5+ years from now I will be threading these parts.
Bluemeanie wrote:
Same thing happened to mine. RetroRiceRocketRider gave me a great idea. I tapped the opening with a 1/8 x 27 pipe thread tap and screwed in a 1/8 x 5/16 brass elbow. Wrapped a little teflon tape on it and seems to work great.
- RetroRiceRocketRider
- Thank you received: 29
