Leaky carbs
- chelms27
Re: Leaky carbs
26 Oct 2008 09:48
I am having the same problem with my 77 kz1000. I plugged the overflow tube just to see what happens and then it started leaking from the air filter?
1977 KZ1000...16k miles 2nd owner all original except tires, dyna-coil, and a vance and hines 4 to 1 exhaust.
- bill_wilcox100
Re: Leaky carbs
26 Oct 2008 10:10 - 26 Oct 2008 10:14
Welcome to the KZR nation... great to have you here. Let's get a picture of this bike...
If you don't have one, install a new inline fuel filter and change it at the beginning of each season. That will prevent any tank or gas debris for lodging in the needle valve or blocking jets or passageways. :huh:
Don't depend on any filter that may or may not be built into the petcock. Don't ask how I know. :blush:
Best of success.
BTW, add your year, model and location to your signature. It will help get the best responses and it's considered real friendly too.
Bill
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 26 Oct 2008 10:14 by bill_wilcox100.
- chelms27
Re: Leaky carbs
26 Oct 2008 13:22
I actually let the gas out of the hole in the bottom of the carb and then tapped it a few times while turning the gas on. I then fired it up and I have no more leak? Thanks for the help.
Re: Leaky carbs
26 Oct 2008 19:33
chelms27 wrote:
leaking from the air filter--- a RED FLAG!
Gasoline may have also entered crankcase. Would sniff-test oil for gasoline odor indicating fuel contamination.
Before cranking the engine, would also play it safe by changing the oil and filter and assuring proper funtioning of the float bowl overflow circuits.
Good Luck!
Good Luck!
