- Thank you received: 109
Bike won't start, please help
- mark1122
- Keep twisting it
06 Mar 2008 12:51 #198744
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Bike won't start, please help
remove the plug. put plug wire on plug.make sure the metal part of the plug is grounded(touching the metal of the motor).now turn the motor over with egnition on.there should be a spark jumping acoss the gap from the center electrode of the plug to the curved ground electrode of the plug. turn the lights out if u must. but it should be obvious.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
- Thank you received: 337
06 Mar 2008 13:21 #198749
by bountyhunter
Replied by bountyhunter on topic Bike won't start, please help
EasyRider1 wrote:
If you hold the plug body grounded to the engine, the spark will be at the plug tip air gap.
Am I loooking for a spark from the plug to the bike or just the tip of the plug?
- Locozuna
06 Mar 2008 15:16 #198768
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Bike won't start, please help
I hope that when you jumped it you did that from a jump battery and not from a running vehicle.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- EasyRider1
06 Mar 2008 16:51 #198789
by EasyRider1
1978 KZ650C
Replied by EasyRider1 on topic Bike won't start, please help
Locozuna wrote:
Not a running vehicle no.
1978 KZ650C
- EasyRider1
06 Mar 2008 16:55 #198790
by EasyRider1
1978 KZ650C
Well guys, I removed the carbs, cleaned them, replaced them. I also checked the spark plugs and yes I'm getting spark in all four. Could this all be from a dead battery? Maybe I will have that checked out. I'm running out of ideas here, any more thoughts?
Post edited by: EasyRider1, at: 2008/03/06 20:17
1978 KZ650C
- Thank you received: 2829
06 Mar 2008 17:08 #198796
by 650ed
Replied by 650ed on topic Bike won't start, please help
A bad battery can prevent a bike from starting. Since I've owned my bike I have had a couple experiences like that when the battery was on its last leg. Try fully charging the battery, dry the plugs (a propane touch works well followed by a wire brush), and then give 'er a try. You may want to kick start it with the freshly charged battery in place; that way you don't have the starter and plugs competing for current. Ed
- EasyRider1
06 Mar 2008 18:54 #198822
by EasyRider1
1978 KZ650C
Alright guys, you are not going to believe what it was. A friggin' pinched battery vent hose!!!:evil: :sick: :whistle:
I pulled the battery getting ready to replace it when the hose came loose, there was this really powereful hiss sound. I looked at the vent hose and it was pinched tight. I put the old battery back on and jumped it off and she started right up. I couldn't believe it!
Then it wouldn't idle right again(just like the other day). I was thinking I was back a square one. I took around the block and it ran really rough and kept going dead. I got back to the house and straightened out the vent hose going all the way down, it wasn't pinched anywhere else, it was just loose in there. Once I did this, the bike seemed to run just right again. How can a battery vent hose caust this much trouble?
It's frustrating to spend hours working on other parts of the bike when it turns out to be something stupid like this. I suppose I will think of it as a learning experience since I now know how to check each system to find a problem. Thanks again for all your help.
1978 KZ650C
