Bike won't start, please help
- EasyRider1
This is the kz650 by the way.
Post edited by: EasyRider1, at: 2008/03/04 21:47
1978 KZ650C
- ronjones
- Thank you received: 4
I painted my bike and put back together. I filled up the tank and rode it around for a little while. Everything seemed ok. Then all of a sudden the next day, the bike won't start. I checked the spark plugs, the fuel is on, the kill switch is off , what could be the problem?
This is the kz650 by the way.<br><br>Post edited by: EasyRider1, at: 2008/03/04 21:47
- EasyRider1
1978 KZ650C
- ronjones
Have you checked your fuses? I've also had a bit of a problem w/my bike loosing power. When I remove the side cover and jiggle the wires, it comes back on. I really do need to replace my fuse box, it's in bad shape. If that doesn't do it you might want to, use a voltmeter, trace the power from the battery and see where the power goes. These are my only real suggestions. Hope it helps.
Ron
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- EasyRider1
I figure that the bike turns over with the starter, so did you check to see if you have spark? and are the plugs wet after you try to start it
I just tried to start it. Then I checked the plugs and they are a little wet. What should I do now?
1978 KZ650C
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
West Linn, OR
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- EasyRider1
I put everything back together and still the same thing. I then tried jumping it off since the battery is dead from trying to start it, that didn't work.
I tried to check to see if I'm getting spark but I'm a little confused on how to do this. I tried it on the kz650 and kz440 (which is running fine) and I couldn't see a spark on either. Exactly how do you do this?
Post edited by: EasyRider1, at: 2008/03/06 00:42
1978 KZ650C
- bountyhunter
- Thank you received: 337
I tried to check to see if I'm getting spark but I'm a little confused on how to do this. I tried it on the kz650 and kz440 (which is runnning fine) and I couldn't see a spark on either. Exactly how do you do this?<br><br>Post edited by: EasyRider1, at: 2008/03/05 18:03
Do you have a timing light? That's an easy way to see if it is sparking at all. If not, it's a two man job. Pull the plugs out. Insert a plug one at a time into each wire and hold the metal body of the plug tight to the engine and have a buddy crank the engine. watch for spark, keep fingers away from the plug tip.
- EasyRider1
1978 KZ650C
