Bike won't start, please help
  • EasyRider1
  • EasyRider1's Avatar Topic Author
04 Mar 2008 18:46
#198442
I painted my bike and put back together. I filled up the tank and rode it around for a little while. Everything seemed ok. Then all of a sudden the next day, the bike won't start. I checked the spark plugs, the fuel is on, the kill switch is off, what could be the problem?
This is the kz650 by the way.
Post edited by: EasyRider1, at: 2008/03/04 21:47
1978 KZ650C
  • ronjones
  • ronjones's Avatar
Re: Bike won't start, please help
04 Mar 2008 19:09
#198447
EasyRider1 wrote:
I painted my bike and put back together. I filled up the tank and rode it around for a little while. Everything seemed ok. Then all of a sudden the next day, the bike won't start. I checked the spark plugs, the fuel is on, the kill switch is off , what could be the problem?
This is the kz650 by the way.<br><br>Post edited by: EasyRider1, at: 2008/03/04 21:47
  • EasyRider1
04 Mar 2008 20:15
#198457
By off I mean not engauged. It is in the middle position.
1978 KZ650C
  • ronjones
  • ronjones's Avatar
05 Mar 2008 05:06
#198500
OK, sorry EasyRider, I figured that's what you ment, just couldn't resist;) :)
Have you checked your fuses? I've also had a bit of a problem w/my bike loosing power. When I remove the side cover and jiggle the wires, it comes back on. I really do need to replace my fuse box, it's in bad shape. If that doesn't do it you might want to, use a voltmeter, trace the power from the battery and see where the power goes. These are my only real suggestions. Hope it helps.
Ron
  • BSKZ650
  • BSKZ650's Avatar
05 Mar 2008 05:34
#198501
I figure that the bike turns over with the starter, so did you check to see if you have spark? and are the plugs wet after you try to start it
77 ltd1000, current rider
76 kz900, just waiting
  • EasyRider1
05 Mar 2008 12:57
#198558
I just tried to start it. Then I checked the plugs and they are a little wet. What should I do now?
1978 KZ650C
  • Locozuna
  • Locozuna's Avatar
05 Mar 2008 13:38
#198566
You checked the spark plugs. Does that mean you checked to see if they were there or that you have a nice juicy fat spark when turning over? If you have spark then your carbs are culprit(s). Possibly when putting the tank back on you loosened a wire or shorted one if you are not getting spark to ALL plugs. Check for spark on all of them.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Skyman
  • Skyman's Avatar
05 Mar 2008 14:24
#198576
I had a similar problem once. One minute, it ran fine. Then next, I couldn't get it started. I checked the plugs, and they were wet with fuel. I can't remember why that happened. But anyhow, I had some extra plugs laying around. I put those in, and varrooooom. It fired right up.
West Linn, OR
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Mar 2008 14:58
#198582
u say the plugs were wet.that says u have fuel. so i would start to look at electrical. could your tank or a wire be grounding out a coil,?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • EasyRider1
05 Mar 2008 15:02
#198583
I drained the tank, cleaned and checked the petcock, put in new spark plugs, removed tank, check all connections that could have been knocked loose when removing/installing the tank.
I put everything back together and still the same thing. I then tried jumping it off since the battery is dead from trying to start it, that didn't work.
I tried to check to see if I'm getting spark but I'm a little confused on how to do this. I tried it on the kz650 and kz440 (which is running fine) and I couldn't see a spark on either. Exactly how do you do this?
Post edited by: EasyRider1, at: 2008/03/06 00:42
1978 KZ650C
  • bountyhunter
  • bountyhunter's Avatar
05 Mar 2008 16:14
#198589
EasyRider1 wrote:
I tried to check to see if I'm getting spark but I'm a little confused on how to do this. I tried it on the kz650 and kz440 (which is runnning fine) and I couldn't see a spark on either. Exactly how do you do this?<br><br>Post edited by: EasyRider1, at: 2008/03/05 18:03
Do you have a timing light? That's an easy way to see if it is sparking at all. If not, it's a two man job. Pull the plugs out. Insert a plug one at a time into each wire and hold the metal body of the plug tight to the engine and have a buddy crank the engine. watch for spark, keep fingers away from the plug tip.
  • EasyRider1
06 Mar 2008 11:37
#198738
Am I loooking for a spark from the plug to the bike or just the tip of the plug?
1978 KZ650C
