Installed pod filters & open exhaust & now I get HORRIBLE mpg
- elcid
If I install this will this make my gas mileage normal?
What should my average mpg be for this bike?
Or is there anything else I should do to get better mpg?
Thanks!
- love2ride
- Ngati Tumatauenga
- Thank you received: 1
I know of someone with a Ducati Monster who upgraded his and put in a jet kit. It did increase his mileage.
Newport News, Va
2006 Ninja 250 - Commuter
1978 KZ1000 - Not even close to stock.
- elcid
- love2ride
- Ngati Tumatauenga
Float height set right?
Newport News, Va
- Rickman
Putting on the pod filters and opening the exhaust would flow more air and lean it out, we usually change to larger jets (your 'stage' kit) to richen the mixture back to an idea range. Did the mechanic do something else to richen the mixture?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- PLUMMEN
- Thank you received: 104
- guitargeek
- Thank you received: 50
try a differant mechinic!if hes got you running around with pods and open exhust and didnt touch the carbs it should be running really lean,get those carbs sorted out before you hole a couple pistons;)
True, but it sounds like the mechanic already rejetted too rich.
elcid, find out exactly what your mechanic did.
It would also help us to help you if we knew which carbs your bike has.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- wiredgeorge
- elcid
Is it possible that I don't need a jet kit at all & he just jetted poorly?
If I do need a jet kit, the which stage should I get??
Thanks guys!
Post edited by: elcid, at: 2008/03/01 13:57
- guitargeek
I am not sure what he did really. He just said that he could only adjust the jets so much & it will not run perfectly smooth until I get a jet kit.
Jet's aren't "adjustable". When you rejet you remove your jets and replace them with jets of a different size (meaning the hole through which the gasoline flows is a different size).
Jets vary, but usually look something like this:
It has Mikuni carbs I believe.
Both the BS32 and VM26 carbs we're talking about are made by Mikuni.
If you have VM26 carbs, they should look something like this:
If you have BS32 carbs, they should look something like my BS34 carbs:
There's a basic rule of thumb for determining what size jets to use and how to adjust the jet needles (if at all). You go up so much if you switch to an open exhaust, so much for pod filters. It's not a precise formula, just kind of a vague guideline to get you in the ball park. I'd recommend you do some searching through the forum to see what others have recommended. Wiredgeorge knows as much about this topic as anybody here...
Post edited by: guitargeek, at: 2008/03/01 16:13
- elcid
Post edited by: elcid, at: 2008/03/01 16:19
- Bluemeanie
- Thank you received: 14
