best carb?
- shiner
best carb?
03 Jan 2008 09:26
what are the best carbs at a fair price to put on a kz1000 with a 1075 kit and mild cams? I know 29 smoothbores would be ideal but other than that
- Sandy
- Fly High,Tony
Re: best carb?
03 Jan 2008 13:30
28mm Mikunis,if You're not already running them on said bike...
1977 KZ1000 A-1
- mark1122
- Keep twisting it
Re: best carb?
03 Jan 2008 14:20
Several options are available. bs34's ,mik. rs32 off an older suzuki,mik. rs 34's , mik. vm 33's, kehin cr's or fcr's.
u will get a great deal of debate as to witch is best.it depends also , what u expect .do u want a killer top end bike, a bottom end torque monster,an all around bike .
smaller carbes will serve the bottom end better,larger the top end.
bs 34s are in the mid.
the 29's probably fall in the mid and are high on price.$400 to $500.
vm33s are better on top with not too much loss on the bottom and are cheeper.$300.
cr ,and rs are upper range in $($450) and performance.then the cfr's
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- shiner
Re: best carb?
03 Jan 2008 15:43
A guy told me that my carbs were 29 smoothbores but I'm kind of doubting they are. They have the 3 screws on top but looking in them they don't look like the smoothbores. They might be 28's. Anyway, they're suppose to be the propper jetting. Don't know for sure, had it running and seemed doggie but could be something else. Haven't had much time to mess with it and was wandering what the ideal carbs would be if I was to replace them and also if my boy wanted to change his on his '81 Ltd.
Re: best carb?
03 Jan 2008 17:35
shiner wrote:
Perhaps this carb ID guide from Z1E might be helpful.
Z1E carb guide
A guy told me that my carbs were 29 smoothbores but I'm kind of doubting they are. They have the 3 screws on top but looking in them they don't look like the smoothbores. They might be 28's....
Z1E carb guide
- saxjonz
- KawboyZ
Re: best carb?
07 Jan 2008 16:35
shiner you can find out really easy. The smoothbores have nuts on the bottom of the bowls that you can remove to change out the jets with. They are rather large. If you have them in the center of the bowls then they are the real deal.
79 LTD B3
- saxjonz
- KawboyZ
Re: best carb?
07 Jan 2008 16:41
Mark just curious to know. How does your bike run on that setup? Overheating issues?
79 LTD B3
- shiner
Re: best carb?
08 Jan 2008 04:27
The carbs are 26's. I may keep them on for awhile but will probably do something else later
- mark1122
- Keep twisting it
Re: best carb?
08 Jan 2008 17:26
no i dont have any heat problems. overall the motor work great.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- saxjonz
- KawboyZ
Re: best carb?
16 Jan 2008 15:46
That sounds great. I bet you don't get caught up with street lights and the such that I experience here in Chicago though and the summers have to be hotter here than there at times I assume. Maybe not.
I am debating whether I should go ape shit and order the ape 1327 big block kit undercut the gears which I am going to do regardless and weld the crank up. Run 34 smoothies or keep my 29 smoothies and just do 1075. My bike runs pretty good and when I hit it good I can smoke the rear tire at 30 without too much but I do have a gear in it and that takes the highway speed down to 80 or so which is revving the engine a little much to keep up with the group I ride with. Questions questions they make me crazy thinking about what the best set up is to run and still keep the bike bullet proof. Overheating issues etc. But that sounds great. I had a zr1100 which I thought was a nice machine but still I yearn for a bit more than that. Dynoed that bike gave 96 at the rear wheel after the v&h pipe. I think I would like to get about 120 or so to be completely happy. I have ridden with guys that have 200hp bikes. But then technology and liquid cooled made that a reality. I have a feeling that if I spend all of this money I might end up with a bike I can only ride when it's cool out and for a short time. Arrg. Decisions.
79 LTD B3
- saxjonz
- KawboyZ
Re: best carb?
16 Jan 2008 15:58
shiner wrote:
The guy I was considering having rebuild my bike told me to get rid of them and get some 34s and with the 1075 and really good head work that would make a huge difference. But a set of those new sell for around 615 dollars. For the money I am going to put into this bike without thinking twice I could certainly buy a haybusa and run stock all day long spanking the kzs around but then it wouldn't be that much fun. I love this crazy bike of mine. I would ask around for sure though about some bigger carbs so you can make that engine wake up and respond like it should
Yeah those carbs are a bit small. If you could find a set of 29s bet they'd put a smile on your face for a bit. When I changed my 26s put dyna ig and plate my bike totally changed around. Instead of pulling wheelies I would mostly end up smokin the rear tire. What a difference can I tell you. I heard that you can get some good suzuki carbs for cheap and if you look around you probably could find a set of 29s on the cheap. I got mine for 150 and I know that they sell for up to 600 dollars and one bike shop mechanic told me that my carbs could fetch a grand. I am going back to sell them to him with a quickness if he gives me a grand or even close to that. They sounded jealous that I had a pair and wanted them. I told them I would consider it if they made me a fair offer. lolThe carbs are 26's. I may keep them on for awhile but will probably do something else later
79 LTD B3
- kawtoy
Re: best carb?
17 Jan 2008 19:46
I have a set of 34mm GS1100 carbs right now on ebay, $150 or best offer :whistle: . All you need is a set of 34mm intakes from zenterprises. I have 34mm on my 1000 but got a set of 29's cheap so they will be switched before spring. The 34's I have on ebay are very clean inside and ready to go.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
