Where is the idle mixture?
- love2ride
- Ngati Tumatauenga
14 Dec 2007 08:36
Newport News, Va
2006 Ninja 250 - Commuter
1978 KZ1000 - Not even close to stock.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: Where is the idle mixture?
14 Dec 2007 08:42
None of the above.
You need to head south (on the bottom of the carbs, I think the front side of the bowls).
West Linn, OR
- loudhvx
14 Dec 2007 08:43
The two you have circled connected to the question mark are the mixture screws. That type is an "air-screw". It controls the amount of air in the idle mixture. Turning it out allows more aire making it leaner. Turning it in allows less air making it richer.
The third one, to the right, is a very fine adjustment for the throttle position. It is used to make all four carbs have the same throttle position.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Skyman
14 Dec 2007 08:44
Oops. My bad. My '78 has different carbs. sorry.
Post edited by: Skyman, at: 2007/12/14 11:45
West Linn, OR
- loudhvx
14 Dec 2007 08:58
Yeah, I also just checked Kawasaki.com, and the side air-screw type is on the '79-'80 diagram. The 78 diagram (KZ1000 A2 and A2A) show it underneath near the engine side. Those would be true mixture screws which contol the amount of air AND fuel for the idle circuit.
The 1000 D shows the side air-screws.
I'm sure WG has the details of what type goes on what bike.
Love2ride, you may want to be more specific with the exact model and letter designation on your bike in the signature. There are a few different 1000's in 1978.
Post edited by: loudhvx, at: 2007/12/14 12:03
1981 KZ550 D1 gpz.
Other links.
Other links.
- love2ride
- Ngati Tumatauenga
14 Dec 2007 11:32
yeah, I forgot to mention that these are 29mm smoothbore Mikuni carbs.
Newport News, Va
- love2ride
- Ngati Tumatauenga
14 Dec 2007 17:14
Being air screw type located on the sides. They are adjusted as usual. Turn in til they are gently seated and then turn out so many turns.
29mm carbs
K&N pods
V&H system
Im thinking 2 ad half to start, maybe three turns out.
29mm carbs
K&N pods
V&H system
Newport News, Va
- loudhvx
14 Dec 2007 17:25
I can't say how many turns. You'll need a manual or maybe WG knows. On my 550's they are all supposed to be less than two turns.
Post edited by: loudhvx, at: 2007/12/14 20:26
1981 KZ550 D1 gpz.
Other links.
Other links.
- love2ride
- Ngati Tumatauenga
14 Dec 2007 17:30
K thanks for the replys.
I saw your sig, I am looking at buying a manual. I will go thru the link to help fund KZrider.
Newport News, Va
15 Dec 2007 02:26
From Z1E website:
29mm smoothbores Z1 / KZ900 / KZ1000
Main Jet 120
Air Jet 0.9
Needle Jet O-6
Jet Needle 5DL31-3
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5 or 20.0 (or 25 in the later versions)
Air Screw setting 1 1/2 turns out
Main Jet 120
Air Jet 0.9
Needle Jet O-6
Jet Needle 5DL31-3
- love2ride
- Ngati Tumatauenga
15 Dec 2007 19:08
Thank you. I really need to go thru the Z1 site and look at everything.
Newport News, Va
15 Dec 2007 20:12
love2ride wrote:
The two closely located screws under the carb top covers are for adjusting height of the throttle slide, which is used when syncing the carbs.
I believe th left pictured screw/nut is the adjusting screw with locknut, and the other serves to lock down the adjustment.
Post edited by: Patton, at: 2007/12/15 23:12
Post edited by: Patton, at: 2007/12/15 23:16
