Best way to clean carbs
  • vach
  • vach's Avatar Topic Author
28 Apr 2007 14:46
#135017
What is the best way to clean the carbs to make them like new again? Etching them with Alconox, Chem-Dip? I don't have a power washer, so I'm trying to figure uot a cheap way to get these new looking again. If I did send out, how much would that cost to thoroughly clean them?
1979 kz650 B. Chicago, Illinois
  • arobsum
  • arobsum's Avatar
Re: Best way to clean carbs
28 Apr 2007 14:56
#135019
buy a gallon of chemtool or similar cleaner at the parts store for less than $20 bucks. works great. even comes with a little tray inside for the brass parts.
  • JMKZHI
  • JMKZHI's Avatar
Re: <<<>>>electroless nickel plating
28 Apr 2007 16:25 - 22 Feb 2013 11:55
#135035
Last edit: 22 Feb 2013 11:55 by JMKZHI.
  • KZErider
  • KZErider's Avatar
28 Apr 2007 16:38
#135044
What did we conclude about Conti's thread about using a mild lemon juice solution and simmering the carb bodies?
Has anyone else tried it?:huh:
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • RonKZ650
  • RonKZ650's Avatar
28 Apr 2007 16:59
#135054
I'll reinterate, don't bother with Chemtool, (although I can't say I've ever tried it so I could be wrong). If it's sold through the normal discount chains, checker, autozone and the like it won't work. Stuff is "safe mode", made to work, but very mildly, but be safe in case you accidently drink a pint of it ;) I'm all for safe where safe is called for, but not here. Get the Napa stuff, it's eaten the paint off the pail it comes in that I have. Now just last week in my saga of clogged pilots, I worked over a set of VM24 airscrew type carbs in my Napa cleaner and you ought to see them, they down right gleem, where they were so cruddy. You're best off removing rubber before putting in the napa cleaner, because rubber turns mushy, but even at that it seems to all return to normal in short order. The instructions say dip parts for 20 min. That's all it takes, believe it or not. Stuff comes out of the dip shiney and clean. I recommend it highly. Sorry to rant on about a product, but in my many years in this world I've seen so much damn crap, stuff that does not work. I hate that! I want something that works and this stuff fits the bill.
  • kawtoy
  • kawtoy's Avatar
28 Apr 2007 20:41
#135129
I have a bucket or Berrymans carb dip. You can have it if you want cause the crap just does not work. When the carbs come out you still have to scrub them to get them anywhere close to clean. I left a CB350 carb bowl in there once for a month. It was badly varnished and stained. I took it out after a month and it looked worse than before. I have also tried dipping them for only an hour with the same results. The come out with a dark grey color and the staind are still there. I think the product is junk. I tried the lemon juice method with hardly any results. I might not have used enough lemon juice but who knows.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • unkle fester
  • unkle fester's Avatar
29 Apr 2007 10:57
#135291
I boil them in a mixture of 50% lemon juice and 50% water.....the acidic content of the lemon juice and agitation of the boiling water works great......they ain't shiney, but they're clean
  • arobsum
  • arobsum's Avatar
29 Apr 2007 16:01
#135360
does this setup clean the inner ports out as well?
  • unkle fester
29 Apr 2007 17:33
#135389
yep.....I have cleaned a few sets like this and cleans everything......
Post edited by: unkle fester, at: 2007/04/29 20:47
  • arobsum
  • arobsum's Avatar
29 Apr 2007 20:28
#135484
cool. cheap and effective. just what i like!:)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
29 Apr 2007 20:36
#135490
You might try boiling them in elephant piss.
No elephant piss? Automatic dishwasher detergent is a good substitute.
  • harm
  • harm's Avatar
  • Tom
30 Apr 2007 17:20
#135743
I went to Napa today to get some of the good stuff(Carb cleaner). Brought it up to the counter and they told me it was $60 for one gallon can! :woohoo: :woohoo: I put it back on the shelf. I guess i will try the lemon juice trick.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
