apasu77 wrote:
I need some help to calculate the exact percent between gas and air in the carburattors. I have looked for an owner's manual or something like that to help me, but I still haven't found what I'm looking for. People I ask keep telling me that it's an old model. You are my last hope. If you have any fiches or even the manual,please don't let me die looking for it
Hello aspasu77 --
Am uncertain about information you are seeking.
Are you asking about how to adjust the carbs?
What year and model of 650?
Please describe problem involved.
All other tune-up steps should be done before any carb adjusting.
If 1977, here is a diagram of the carb.
Ref # Part # Description Qty Spec #
1 16005-027
Add to pick list TOP,MIXING CHAMBER 4 4
1 16005-027
2 223B0414
Add to pick list SCREW-PAN-WS-CROS 2
3 461F0400
Add to pick list WASHER SPRING 4MM 6
4 16019-031
Add to pick list GASKET,CHAMBER TOP 4 4
4 16019-031
5 16003-013
Add to pick list NUT,5MM 4 4
5 16003-013
6 461F0500
Add to pick list WASHER SPRING 5MM 8 8
6 461F0500
7 16039-016
Add to pick list WASHER,PLAIN 4 4
7 16039-016
8 16046-012
Add to pick list SCREW,SLOTTED 4 4
8 16046-012
9 16057-002
Add to pick list SEAT,SPRING 4 4
9 16057-002
10 16040-026
Add to pick list SPRING 4 4
10 16040-026
11 16067-006
Add to pick list BOLT,HEX HEAD,5X14 4 4
11 16067-006
12 39075-1001
Add to pick list LEVER,THROTTLE 4 4
12 39075-1001
13 16033-031
Add to pick list SCREW,PAN HEAD,3X14 8 8
13 16033-031
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-272)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1020)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1022)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1069)
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 0 4
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 4 4
14 39184-1001
15 16008-010
Add to pick list CIRCLIP 4 4
15 16008-010
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-272)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1020)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1022)
16 16009-1013
Add to pick list JET NEEDLE,5CN15 4 (for 16001-1069)
16 16009-1015
Add to pick list JET NEEDLE,5CL10 4 (for 16001-1026)
16 16009-1029
Add to pick list JET NEEDLE,5CL16 0 4
16 16009-1029
Add to pick list JET NEEDLE,5CL16 4
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1020)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1022)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1069)
17 16025-1016
Add to pick list VALVE,THROTTLE,CA2.0 4 (for 16001-1026)
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 0 4
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 4
18 16076-003
18 16076-003
19 16073-014
Add to pick list COLLAR 4 4
19 16073-014
20 16039-015
Add to pick list CAP,STARTER PLUNGER 4 4
20 16039-015
21 16012-015
21 16012-015
22 670B1509
Add to pick list "O" RING,9MM 4 4
22 670B1509
23 16013-008
Add to pick list SPRING,STARTER PLUG 4 4
23 16013-008
24 16016-021
Add to pick list PLUNGER,STARTER 4 4
24 16016-021
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-272)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1020)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1022)
25 16017-1021
Add to pick list NEEDLE JET,0-4 4 (for 16001-1069)
25 16017-1018
Add to pick list NEEDLE JET,AO-7 4 (for 16001-1026)
25 16017-1034
Add to pick list NEEDLE JET,AO-5 0 4
25 16017-1034
Add to pick list NEEDLE JET,AO-5 4
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-272)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1020)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1022)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1069)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1026)
26 49122-1006
Add to pick list PIPE,BLEED 0 4
26 49122-1006
27 16038-016
Add to pick list "0" RING,MAIN JET COV 8 8
27 16038-016
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-272)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1020)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1022)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1069)
28 92063-1029
Add to pick list MAIN JET,#A90R 4 (for 16001-1026)
28 92063-1035
Add to pick list MAIN JET,#A97.5R 0 4
28 92063-1035
Add to pick list MAIN JET,#A97.5R 4
28 92063-1033
Add to pick list MAIN JET,#A100 4 4
28 92063-1033
28 92063-1042
Add to pick list MAIN JET,#A105R 4 4
28 92063-1042
28 92063-073
Add to pick list JET-MAIN NO 107.5R 4 4
28 92063-073
28 92063-068
Add to pick list MAIN JET NO 92.5R 4 4
28 92063-068
28 92063-1031
Add to pick list MAIN JET,#A95 4 4
28 92063-1031
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-272)
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-1026)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-272)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-1026)
31 16038-024
Add to pick list "O" RING 4 (for 16001-272)
31 16038-024
Add to pick list "O" RING 4 (for 16001-1026)
32 16012-022
Add to pick list CAP,LIMTTER 4 (for 16001-1026)
32 11012-1041
Add to pick list CAP,LIMITER 4 (for 16001-1026)
33 16029-004
Add to pick list WASHER FLOAT VLV SEAT 4 4
33 16029-004
34 16030-1001
Add to pick list FLOAT VALVE ASSY 4 4
34 16030-1001
35 92064-1018
Add to pick list PILOT JET,#A15 4 4
35 92064-1018
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-272)
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-1026)
37 16031-031
Add to pick list FLOAT 4 4
37 16031-031
38 16032-003
Add to pick list FLOAT PIN 4 4
38 16032-003
39 11009-1563
Add to pick list GASKET,FLOAT CHAMBER 4 4
39 11009-1563
40 220B0416
Add to pick list SCREW PAN HEAD 4X16 6
41 16049-007
Add to pick list SCREW,GUIDE 4 4
41 16049-007
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 0 4
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 4 4
42 16014-1004
42 16014-1004
42 16014-1006
Add to pick list SCREW,AIR ADJUSTING 4 (for 16001-1069)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1020)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1022)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1069)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1020)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1022)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1069)
45 13169-1107
Add to pick list PLATE,JET NEEDLE 0 4
45 13169-1107
Add to pick list PLATE,JET NEEDLE 4 4
45 13169-1107
46 92027-1103
Add to pick list RING,JET NEEDLE 0 4
46 92027-1103
Add to pick list RING,JET NEEDLE 4 4
46 92027-1103
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 0 4
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 4 4
47 92022-1024
48 92081-1072
Add to pick list SPRING,JET NEEDLE 0 4
48 92081-1072
Add to pick list SPRING,JET NEEDLE 4 4
48 92081-1072
