Kz 650 carburattor need help psl
- apasu77
13 Mar 2007 14:23
I need some help to calculate the exact percent between gas and air in the carburattors. I have looked for an owner's manual or something like that to help me, but I still haven't found what I'm looking for. People I ask keep telling me that it's an old model. You are my last hope. If you have any fiches or even the manual,please don't let me die looking for it
- OKC_Kent
Re: Kz 650 carburattor need help psl
13 Mar 2007 14:32
Why are you looking for this kind of information? Is it specifically to find out what fuel/air ratio is required to make an engine run? Start here if that's what you need.
en.wikipedia.org/wiki/Air-fuel_ratio
Cashion, OK
78 KZ650 B2 85,000+ miles
13 Mar 2007 17:08
apasu77 wrote:
Hello aspasu77 --
Am uncertain about information you are seeking.
Are you asking about how to adjust the carbs?
What year and model of 650?
Please describe problem involved.
All other tune-up steps should be done before any carb adjusting.
If 1977, here is a diagram of the carb.
Ref # Part # Description Qty Spec #
1 16005-027
Add to pick list TOP,MIXING CHAMBER 4 4
1 16005-027
2 223B0414
Add to pick list SCREW-PAN-WS-CROS 2
3 461F0400
Add to pick list WASHER SPRING 4MM 6
4 16019-031
Add to pick list GASKET,CHAMBER TOP 4 4
4 16019-031
5 16003-013
Add to pick list NUT,5MM 4 4
5 16003-013
6 461F0500
Add to pick list WASHER SPRING 5MM 8 8
6 461F0500
7 16039-016
Add to pick list WASHER,PLAIN 4 4
7 16039-016
8 16046-012
Add to pick list SCREW,SLOTTED 4 4
8 16046-012
9 16057-002
Add to pick list SEAT,SPRING 4 4
9 16057-002
10 16040-026
Add to pick list SPRING 4 4
10 16040-026
11 16067-006
Add to pick list BOLT,HEX HEAD,5X14 4 4
11 16067-006
12 39075-1001
Add to pick list LEVER,THROTTLE 4 4
12 39075-1001
13 16033-031
Add to pick list SCREW,PAN HEAD,3X14 8 8
13 16033-031
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-272)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1020)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1022)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1069)
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 0 4
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 4 4
14 39184-1001
15 16008-010
Add to pick list CIRCLIP 4 4
15 16008-010
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-272)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1020)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1022)
16 16009-1013
Add to pick list JET NEEDLE,5CN15 4 (for 16001-1069)
16 16009-1015
Add to pick list JET NEEDLE,5CL10 4 (for 16001-1026)
16 16009-1029
Add to pick list JET NEEDLE,5CL16 0 4
16 16009-1029
Add to pick list JET NEEDLE,5CL16 4
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1020)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1022)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1069)
17 16025-1016
Add to pick list VALVE,THROTTLE,CA2.0 4 (for 16001-1026)
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 0 4
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 4
18 16076-003
18 16076-003
19 16073-014
Add to pick list COLLAR 4 4
19 16073-014
20 16039-015
Add to pick list CAP,STARTER PLUNGER 4 4
20 16039-015
21 16012-015
21 16012-015
22 670B1509
Add to pick list "O" RING,9MM 4 4
22 670B1509
23 16013-008
Add to pick list SPRING,STARTER PLUG 4 4
23 16013-008
24 16016-021
Add to pick list PLUNGER,STARTER 4 4
24 16016-021
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-272)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1020)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1022)
25 16017-1021
Add to pick list NEEDLE JET,0-4 4 (for 16001-1069)
25 16017-1018
Add to pick list NEEDLE JET,AO-7 4 (for 16001-1026)
25 16017-1034
Add to pick list NEEDLE JET,AO-5 0 4
25 16017-1034
Add to pick list NEEDLE JET,AO-5 4
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-272)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1020)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1022)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1069)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1026)
26 49122-1006
Add to pick list PIPE,BLEED 0 4
26 49122-1006
27 16038-016
Add to pick list "0" RING,MAIN JET COV 8 8
27 16038-016
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-272)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1020)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1022)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1069)
28 92063-1029
Add to pick list MAIN JET,#A90R 4 (for 16001-1026)
28 92063-1035
Add to pick list MAIN JET,#A97.5R 0 4
28 92063-1035
Add to pick list MAIN JET,#A97.5R 4
28 92063-1033
Add to pick list MAIN JET,#A100 4 4
28 92063-1033
28 92063-1042
Add to pick list MAIN JET,#A105R 4 4
28 92063-1042
28 92063-073
Add to pick list JET-MAIN NO 107.5R 4 4
28 92063-073
28 92063-068
Add to pick list MAIN JET NO 92.5R 4 4
28 92063-068
28 92063-1031
Add to pick list MAIN JET,#A95 4 4
28 92063-1031
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-272)
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-1026)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-272)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-1026)
31 16038-024
Add to pick list "O" RING 4 (for 16001-272)
31 16038-024
Add to pick list "O" RING 4 (for 16001-1026)
32 16012-022
Add to pick list CAP,LIMTTER 4 (for 16001-1026)
32 11012-1041
Add to pick list CAP,LIMITER 4 (for 16001-1026)
33 16029-004
Add to pick list WASHER FLOAT VLV SEAT 4 4
33 16029-004
34 16030-1001
Add to pick list FLOAT VALVE ASSY 4 4
34 16030-1001
35 92064-1018
Add to pick list PILOT JET,#A15 4 4
35 92064-1018
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-272)
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-1026)
37 16031-031
Add to pick list FLOAT 4 4
37 16031-031
38 16032-003
Add to pick list FLOAT PIN 4 4
38 16032-003
39 11009-1563
Add to pick list GASKET,FLOAT CHAMBER 4 4
39 11009-1563
40 220B0416
Add to pick list SCREW PAN HEAD 4X16 6
41 16049-007
Add to pick list SCREW,GUIDE 4 4
41 16049-007
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 0 4
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 4 4
42 16014-1004
42 16014-1004
42 16014-1006
Add to pick list SCREW,AIR ADJUSTING 4 (for 16001-1069)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1020)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1022)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1069)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1020)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1022)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1069)
45 13169-1107
Add to pick list PLATE,JET NEEDLE 0 4
45 13169-1107
Add to pick list PLATE,JET NEEDLE 4 4
45 13169-1107
46 92027-1103
Add to pick list RING,JET NEEDLE 0 4
46 92027-1103
Add to pick list RING,JET NEEDLE 4 4
46 92027-1103
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 0 4
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 4 4
47 92022-1024
48 92081-1072
Add to pick list SPRING,JET NEEDLE 0 4
48 92081-1072
Add to pick list SPRING,JET NEEDLE 4 4
48 92081-1072
Hello aspasu77 --
1 16005-027
1 16005-027
2 223B0414
3 461F0400
4 16019-031
4 16019-031
5 16003-013
5 16003-013
6 461F0500
6 461F0500
7 16039-016
7 16039-016
8 16046-012
8 16046-012
9 16057-002
9 16057-002
10 16040-026
10 16040-026
11 16067-006
11 16067-006
12 39075-1001
12 39075-1001
13 16033-031
13 16033-031
14 16007-028
14 16007-028
14 16007-028
14 16007-028
14 39184-1001
14 39184-1001
14 39184-1001
15 16008-010
15 16008-010
16 16009-071
16 16009-071
16 16009-071
16 16009-1013
16 16009-1015
16 16009-1029
16 16009-1029
17 16025-1006
17 16025-1006
17 16025-1006
17 16025-1016
17 16025-1025
17 16025-1025
18 16076-003
18 16076-003
19 16073-014
19 16073-014
20 16039-015
20 16039-015
21 16012-015
21 16012-015
22 670B1509
22 670B1509
23 16013-008
23 16013-008
24 16016-021
24 16016-021
25 16017-096
25 16017-096
25 16017-096
25 16017-1021
25 16017-1018
25 16017-1034
25 16017-1034
26 16047-005
26 16047-005
26 16047-005
26 16047-005
26 16047-005
26 49122-1006
26 49122-1006
27 16038-016
27 16038-016
28 92063-1028
28 92063-1028
28 92063-1028
28 92063-1028
28 92063-1029
28 92063-1035
28 92063-1035
28 92063-1033
28 92063-1033
28 92063-1042
28 92063-1042
28 92063-073
28 92063-073
28 92063-068
28 92063-068
28 92063-1031
28 92063-1031
29 16022-016
29 16022-016
30 16014-018
30 16014-018
31 16038-024
31 16038-024
32 16012-022
32 11012-1041
33 16029-004
33 16029-004
34 16030-1001
34 16030-1001
35 92064-1018
35 92064-1018
36 92064-1019
36 92064-1019
37 16031-031
37 16031-031
38 16032-003
38 16032-003
39 11009-1563
39 11009-1563
40 220B0416
41 16049-007
41 16049-007
42 16014-1004
42 16014-1004
42 16014-1004
42 16014-1004
42 16014-1006
43 16038-022
43 16038-022
43 16038-022
44 16022-007
44 16022-007
44 16022-007
45 13169-1107
45 13169-1107
45 13169-1107
46 92027-1103
46 92027-1103
46 92027-1103
47 92022-1024
47 92022-1024
47 92022-1024
48 92081-1072
48 92081-1072
48 92081-1072
- rstnick
13 Mar 2007 17:59
Someone here will have the info you need, I've got 3 different Manuals.
We just need to know what year/model (looks like a C model) you have and what exactly you want to do.
Post edited by: rstnick, at: 2007/03/16 21:37
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- rstnick
13 Mar 2007 18:00
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- apasu77
16 Mar 2007 01:44
What year and model of 650? Z650 c
Are you asking about how to adjust the carbs? Yes i do
What year and model of 650? 1985 registration
- apasu77
16 Mar 2007 01:51Attachments:
- indykaw77
16 Mar 2007 05:06
Dunno about bike carbs/engines......but back in the day when I was spinnin' wrenches at the Chevy dealer, air/fuel ratio was "supposed to be" 14.7 to 1. This could be fiddled with til late 70's or so, if memory serves, then "they" decided to seal the mixture adjustment screws.:pinch:
rstnick....your 2nd post with carb diagram....thanks! I really got to get a factory shop manual:whistle: :pinch:
Kawasaki Motorcycles...because cars lean th wrong way!
- JimatMilkyWay
16 Mar 2007 09:33
apasu77 wrote:
Do you actually own a wideband a/f ratio meter and do you have some provision to connect to your ride? Just curious.
Hi apasu77 and welcome to the forum.I need some help to calculate the exact percent between gas and air in the carburattors....Dunno about bike carbs/engines......but back in the day when I was spinnin' wrenches at the Chevy dealer, air/fuel ratio was "supposed to be" 14.7 to 1
- rstnick
16 Mar 2007 18:15
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- rstnick
16 Mar 2007 18:47
I've added even more pages to the posts of mine above. Hope this helps.
This site may be of help as well:
www.wgcarbs.com/
www.wgcarbs.com/
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- wiredgeorge
17 Mar 2007 06:48
rstnick,
I removed some text from this post because:
PRODUCT OR SERVICE ADVERTISING IS STRICTLY FORBIDDEN
KZrider.com is not a place for you to solicit sales of any kind. No member is allowed to refer to their own business, or any business to which he/she is associated, through the discussion forum or personal messaging system (U2U). The only exception is that each member is allowed a simple link ( somesite.com ) in their signature. The link shall include no description of any kind.
Now back to WG's post.
KZCSI
As far as tuning the carburetors, 14:1 air/fuel ratio IS NOT optimal for every range of operation... Each circuit in the carburetor has an optimal ratio (they are all close but not exactly 14:1) and at open throttle, 14:1 would be very rich. At idle it would be lean.
We received an old steel exhaust system yesterday where we are going to install an exhaust gas analyzer sensor for more precise testing when we do road tests to be able to more quickly and accurately set up jetting. After the pipe gets cleaned up and finished, we will get the sensor welded into the collector.
Post edited by: KZCSI, at: 2007/03/17 11:11
KZCSI
