A Carb problem?
  • slater_kz550
  • slater_kz550's Avatar Topic Author
A Carb problem?
06 Jan 2007 20:18
#103866
I'm having a wierd problem. My KZ550 is starting to bog down sometimes, and I can really feel it when it wants to go. It'll just take off then go back to bogged down mode. So I let it sit over night to decide what it wants to do.
This morning I started it up, let it run for a couple of minutes and shut it down. Then I felt the heat coming of the headers. All were hot except cylinder one. I checked for a spark, and its got a good spark. So then I figure its a carb problem, so I put some Sea Foam carb cleaner in it and start it back up. It sounds horrible, sputtering, bogging, and just barely idling. Then I feel for heat again and this time 1 and 4 are hot, but 2 and 3 are cool. I let it sit for a while and tried to think it out. Then I went back out in the evening and started it up again and VVVRRROOOOOMMMMM it really started up! All cylinders heated up this time(I've got a burned index finger to prove it).
So I guess my question is when do you decide to rebuild and tune your carbs? And is it really as easy as everyone says it is?
  • arobsum
  • arobsum's Avatar
Re: A Carb problem?
06 Jan 2007 21:26
#103876
well, if you take them apart, keep all the parts in seperate baggies for that particular carb...and do not mess with the settings. most carbs will come apart without messing with the adjusters. my first set was like that and it worked fine. a good manual wouldn't hurt either. as for the airscrews, count the turns out and put them back the same. there are folks on this site who are pro's with these things. have patience and you will get the answers you need. good luck.
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: A Carb problem?
07 Jan 2007 07:33
#103915
Have you considered an electrical problem? I lost most of last summer's riding trying to adjust my way out of problems when I really had electrical problems (OK, some cab stuff too). Since it was a dropped bike it had problems from switch gear faults to ignition faults.
Cold exhaust pipes... some times one, sometimes another, sometimes none. If it is like mine, I had coil problems... there was spark alright but not enough to always start or complete gas combustion. The main symptom I should have addressed first was the sooty spark plugs. You will want to check yours.
By the way, have done the coil power relay modification? It was a big help for me as far as reliability.
Hope this helps. Best of success
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • bill_wilcox100
Re: A Carb problem?
07 Jan 2007 07:36
#103916
Upgrades:
Montreal, Canada
  • bill_wilcox100
Re: A Carb problem?
07 Jan 2007 09:36
#103945
Upgrades:
Montreal, Canada
  • slater_kz550
Re: A Carb problem?
07 Jan 2007 09:59
#103949
The coil power relay modification? Never heard of it. Where can I get one?
  • arobsum
  • arobsum's Avatar
Re: A Carb problem?
07 Jan 2007 10:06
#103951
search this site for wiredgeorge posts. it is a mod you can do to your coils that increases voltage..it was his idea.
  • slater_kz550
Re: A Carb problem?
07 Jan 2007 10:21
#103953
I found this,
www.wgcarbs.com/59021.html
Is this the modification your talking about?
  • arobsum
  • arobsum's Avatar
Re: A Carb problem?
07 Jan 2007 11:27
#103973
slater_kz550 wrote:
I found this,
thats looks like it!! good luck!
  • bill_wilcox100
Re: A Carb problem?
07 Jan 2007 17:01
#104019
That's it! Don't forget the inline fuse. Best of success.
Upgrades:
Montreal, Canada
  • slater_kz550
Re: A Carb problem?
07 Jan 2007 20:36
#104099
Thanks guys, I'll give it a whirl. I dont have much choice since I'm having a hell of a time finding new coils online.
  • arobsum
  • arobsum's Avatar
Re: A Carb problem?
08 Jan 2007 15:08
#104281
go to z1enterprises.com
they have dyna coils new for 120.00.. they are currently out of stock...i am going to wait for them...you can to if you have the time! good luck.
