A Carb problem?
- slater_kz550
A Carb problem?
06 Jan 2007 20:18
I'm having a wierd problem. My KZ550 is starting to bog down sometimes, and I can really feel it when it wants to go. It'll just take off then go back to bogged down mode. So I let it sit over night to decide what it wants to do.
This morning I started it up, let it run for a couple of minutes and shut it down. Then I felt the heat coming of the headers. All were hot except cylinder one. I checked for a spark, and its got a good spark. So then I figure its a carb problem, so I put some Sea Foam carb cleaner in it and start it back up. It sounds horrible, sputtering, bogging, and just barely idling. Then I feel for heat again and this time 1 and 4 are hot, but 2 and 3 are cool. I let it sit for a while and tried to think it out. Then I went back out in the evening and started it up again and VVVRRROOOOOMMMMM it really started up! All cylinders heated up this time(I've got a burned index finger to prove it).
So I guess my question is when do you decide to rebuild and tune your carbs? And is it really as easy as everyone says it is?
- arobsum
Re: A Carb problem?
06 Jan 2007 21:26
well, if you take them apart, keep all the parts in seperate baggies for that particular carb...and do not mess with the settings. most carbs will come apart without messing with the adjusters. my first set was like that and it worked fine. a good manual wouldn't hurt either. as for the airscrews, count the turns out and put them back the same. there are folks on this site who are pro's with these things. have patience and you will get the answers you need. good luck.
- bill_wilcox100
Re: A Carb problem?
07 Jan 2007 07:33
Have you considered an electrical problem? I lost most of last summer's riding trying to adjust my way out of problems when I really had electrical problems (OK, some cab stuff too). Since it was a dropped bike it had problems from switch gear faults to ignition faults.
Cold exhaust pipes... some times one, sometimes another, sometimes none. If it is like mine, I had coil problems... there was spark alright but not enough to always start or complete gas combustion. The main symptom I should have addressed first was the sooty spark plugs. You will want to check yours.
By the way, have done the coil power relay modification? It was a big help for me as far as reliability.
Hope this helps. Best of success
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- bill_wilcox100
Re: A Carb problem?
07 Jan 2007 07:36
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- bill_wilcox100
Re: A Carb problem?
07 Jan 2007 09:36
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- slater_kz550
Re: A Carb problem?
07 Jan 2007 09:59
The coil power relay modification? Never heard of it. Where can I get one?
- arobsum
Re: A Carb problem?
07 Jan 2007 10:06
slater_kz550 wrote:
search this site for wiredgeorge posts. it is a mod you can do to your coils that increases voltage..it was his idea.The coil power relay modification? Never heard of it. Where can I get one?
- slater_kz550
Re: A Carb problem?
07 Jan 2007 10:21Please Log in or Create an account to join the conversation.
- arobsum
- bill_wilcox100
Re: A Carb problem?
07 Jan 2007 17:01
That's it! Don't forget the inline fuse. Best of success.
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- slater_kz550
Re: A Carb problem?
07 Jan 2007 20:36
Thanks guys, I'll give it a whirl. I dont have much choice since I'm having a hell of a time finding new coils online.
- arobsum
Re: A Carb problem?
08 Jan 2007 15:08
slater_kz550 wrote:
they have dyna coils new for 120.00.. they are currently out of stock...i am going to wait for them...you can to if you have the time! good luck.
go to z1enterprises.comThanks guys, I'll give it a whirl. I dont have much choice since I'm having a hell of a time finding new coils online.
