Borrow Piston Ring Compressor? (kz1000)
- seanile
- let's try this one more time with feeling.
04 May 2018 16:07
hey friends! hoping to borrow a ring compressor for a kz1000 (72 or 73mm i believe, i can confirm if you have one about there) sometime later this month, or in early june. i'm still cleaning the cylinder cover and valves so i'm not in a rush
, just wanted to check before i buy one like i did for the valve compressor haha.
i'm happy to provide a reasonable, refundable deposit for the tool and pay for shipping to and from if you are so kind to lend it to me.
happy to chat on the phone if you'd prefer additional vetting, i promise i'm just trying to get a nice old bike up and going again!
much appreciation,
sean
much appreciation,
sean
1982 Kawasaki KZ1000K LTD
2014 Yamaha Bolt XVS950
- M_a_t_t
Re: Borrow Piston Ring Compressor? (kz1000)
04 May 2018 16:23
Location might be helpful. Maybe someone nearby has one.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- seanile
06 May 2018 20:55 - 06 May 2018 20:55fair, sorry. i'm in boston and would be willing to travel a lil bit to get it, 100 miles id sayM_a_t_t wrote: Location might be helpful. Maybe someone nearby has one.
Last edit: 06 May 2018 20:55 by seanile.
06 May 2018 21:24
I use hose clamps.
- riturbo
07 May 2018 04:20 - 07 May 2018 04:20SWest wrote: I use hose clamps.
Same here . I connect 2 hose clamps toreather . Makes it easier to get them out after .Having a buddy help hold the cylinder helps too .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 07 May 2018 04:20 by riturbo.
- Warren3200gt
07 May 2018 04:34
Cut a section from a plastic fizzy drink bottle and use cable ties around it. (not sure what you call cable ties over the pond)
- DoctoRot
07 May 2018 13:09 - 07 May 2018 13:10
Ive messed around with ring compressors a few times and have found its easiest to just do it by hand. (if the bores are chamfered at the bottom) Put 2&3 at TDC, compress the rings with your fingertips, work back and forth from 2 to 3 until they slide in, then do 1 & 4. a small screw driver can help to poke the ring in but be careful. It can be done in about 10 minutes.
Last edit: 07 May 2018 13:10 by DoctoRot.
The following user(s) said Thank You: KZ Rat
- KZB2 650
08 May 2018 07:27DoctoRot wrote: Ive messed around with ring compressors a few times and have found its easiest to just do it by hand. (if the bores are chamfered at the bottom) Put 2&3 at TDC, compress the rings with your fingertips, work back and forth from 2 to 3 until they slide in, then do 1 & 4. a small screw driver can help to poke the ring in but be careful. It can be done in about 10 minutes.
Jay from APE recommended this and it was easy as pie...... the hose clamps sound good too but by hand worked great for me.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- seanile
08 May 2018 08:11
thank you for the great advice everyone! i've got a few friends who would be willing to help me try these out in good order. good to know that it can be done by hand, carefully
08 May 2018 12:43KZB2 650 wrote:DoctoRot wrote: Ive messed around with ring compressors a few times and have found its easiest to just do it by hand. (if the bores are chamfered at the bottom) Put 2&3 at TDC, compress the rings with your fingertips, work back and forth from 2 to 3 until they slide in, then do 1 & 4. a small screw driver can help to poke the ring in but be careful. It can be done in about 10 minutes.
Just use large amounts of oil to lube the rings
The following user(s) said Thank You: seanile
- PaintWorkz
28 May 2018 14:01
I have a factory ring compressor for the KZ1000 70mm bore. I did not think it worked easily and reverted to pushing the rings in with my fingernails. I assembled new rings and bore dry because back in the day race motors went together that way because there was no break in period.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
