anyone? alot of people look but noone knows?
  • customkzft
  • customkzft's Avatar Topic Author
30 Oct 2006 20:31
#88742
Ok so my starter hasnt worked in a while so when i want to ride i have to push start it, the rebuilt kit is on the way but i can't go a day without riding, you guys understand,
anyway the battery is dead so at first the spark isn't so hot but after i run it for a sec it gets going,
ok the problem today i was riding to work when a car cut me of and had to slam on the breaks making me stall
so usually i'll just have to push it a few feet and pop the clutch and the bike gets going again, usually the compression is pretty hard, i mean it;s hard to turn that rear wheel when the clutch is released, but now after having this insident today i can walk next to the bike in first gear and the compression is not as hard. whats going on? tranny? gears? the pistons have comression.
Now i know push starting is not practical at all but can it really mess u the tranny? engine?
any help is apreciated. thanx guys :S
Post edited by: customkzft, at: 2006/10/31 17:16
  • customkzft
Re: anyone? alot of people look but noone knows?
31 Oct 2006 14:20
#88903
No one?:(
  • The Milkman
  • The Milkman's Avatar
31 Oct 2006 14:25
#88905
A little more information might help. Does it run any different? Make any new noises? Anything different at all????
Les
Maybe, getting the crap scared out of you got your adrenolin going and it just seems easier.
Post edited by: The Milkman, at: 2006/10/31 17:27
  • 77KZ650
  • 77KZ650's Avatar
31 Oct 2006 14:41
#88906
maybe everything is just moving easier since the oil is hot and runny, not cold and thick...
07 MDP Rookie of the Year
  • baldy110
  • baldy110's Avatar
31 Oct 2006 14:46
#88907
Clutch might be slipping. We need some more info to make a better diagnosis.
  • KB02
  • KB02's Avatar
31 Oct 2006 15:21
#88914
Just a shot in the dark, but are all the plugs tight? If one or more is loose for some reason, that would ease up on the compression allot.
That and just make sure that you are in first gear.
Other than that, I'm clueless.
  • vegasjetskier
  • vegasjetskier's Avatar
31 Oct 2006 17:56
#88949
What gear were you in? A higher gear will make it easier to push.
  • nads.com
  • nads.com's Avatar
31 Oct 2006 23:14
#89003
clutch cables can get sticky, clutch plates can crumble, timing chains can jump. Make sure the release arm on the clutch shaft is all the way released.
  • customkzft
01 Nov 2006 04:38
#89023
thanx guys It's in first gear when i turn the engine, the oil is cold, plugs are tight
It might be the clutch??
It just feels like there is no compression i can't start it until i rebuild the starter, but thanx for all the suggestions keep em coming
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Nov 2006 08:04
#89773
Sounds like there are a few problems here.You said the battery is dead.You need to get that manual out and run through the tests to see if you have a charging problem.Is clutch sticking?Do you have a compresion testor?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • loudhvx
  • loudhvx's Avatar
05 Nov 2006 20:06
#89900
Can you shift through all the gears? Can you hear or feel the engine turning over like before?
I've never been able to push start in 1st gear, too hard and the back tire would slip too much. I always use 3rd for push starts, but even then I couldn't just walk next to it indefinitely (my gpz has higher compression, though).
Just remember to not ride off immediately, let some oil pressure build up for 10 or 20 seconds before taking off. I do wonder, though, if it may be bad since the motor is starting under a slight load while connected to the bike and the load is in heavy pulses before the oil pressure builds up and before you can pull the clutch back in.
  • kzwolfsr
  • kzwolfsr's Avatar
07 Nov 2006 16:13
#90314
main question is whats wrong with your kick starter? I havent looked to see what bike you have before i asked that question
Original man of the Caribbean
