UNREMOVABLE BOLT
- mjansen4
1977 KZ650B1 - Mostly stock except for some appearance mods.
- geerbangr
- Thank you received: 4
1978 KZ 1000
I go by Jason
- Jackman
- ronjones
Hey Kawa,I've been in your shoes more times than i care to think,craftsman makes a set of sockets for rounded head removal,they work very well,they're fairly cheap and you can buy them buy the set or indivdually,one of the best tool investments you'll ever make.
I totally agree w/banger, Craftsman makes several types of extractors. I've had to use them all to get the various buggered screws, nuts and bolts out of my project. However, if I had used an impact wrench before I buggered the bolts, in the first place, I may not have needed the extractors.
- letthegoodtimesroll
- Thank you received: 1
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- kawadruida
Unfortunately I don´t have the Crafstman extractor set and down here things like that are pretty expensive...
I´ll give it a shot this weekend, first pouring some drops of WD40 (our version of Marvel Mystery Oil, I guess) then the filing bolt/smaller wrench trick. If this doesn´t work, I better have those vise-grips around...
Wish me luck!
- guitargeek
- Thank you received: 50
Right before you put the vise grips on the bolt, tap it lightly with a hammer.
No need to file the bolt head down if you're going to use vise grips.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- weirdooh
- wiredgeorge
Using a Dremmel tool to cut a slot and then using a flat blade screw driver doesn't work all that great. The slot tends to strip easily and you get little leverage using a standard screwdriver. If you try this method, use a hand impact driver with a bit that fits in the slot tightly. This could also work. A plain old flat blade screwdriver is unlikely to work well so if you try one first, just be sure to not round the edges on the slot you have cut.
Post edited by: wiredgeorge, at: 2006/08/29 14:34
- arobsum
- Thank you received: 10
- wiredgeorge
- kzwanna
i have a set of these they are called bolt-out do a search on ebay there are some listed --i do commercial heating --we find and run into alot of rounded rusted bolts --if they are going to come these will do the trick --i use them with a ratchet -after spraying aerokroil -or pb blaster -keep pressure on them , lightly TAP with a hammer ---if its going to come out this will do it --if the bolts are real bad they will break --Hey Kawa,I've been in your shoes more times than i care to think,craftsman makes a set of sockets for rounded head removal,they work very well,they're fairly cheap and you can buy them buy the set or indivdually,one of the best tool investments you'll ever make.
