Vance and Hines installation
- 79MKII
- Love Them Kaws!
Re: Vance and Hines installation
20 Mar 2008 08:08 - 20 Mar 2008 08:11
The collars should line up but the 1000's have 8mm studs vs 6mm for the 900's. I'm not sure if it would work OK or not. You could always change your studs, but that seems like a lot of work. Maybe you'd just need a bigger washer under the nut? Hopefully someone will post that has actually tried it. I just wanted to mention that there is definitely a difference in studs and collars.
The Kaw List:
Last edit: 20 Mar 2008 08:11 by 79MKII.
20 Mar 2008 12:11 - 20 Mar 2008 12:34
Redline says the smooth aluminum exhaust clamps for 8mm studs may also be used with 6mm studs, and includes extra washers in the fitment kit for using on 6mm studs.
Here's the Redline listing with info, pics, and prices:
Exhaust Clamps
The smooth oem exhaust clamps offered by Z1E don't mention being also for using on 900's. Wonder why?
Also wondering what changed on the 81 models.
Z1E version (same Z1E link 531blackbanshee already furnished)
Besides the difference in appearance, the smooth version is aluminum which may be polished, whereas the oem sunburst style is chrome-plated steel/pot-metal/whatever.
Am using 8mm studs on my 73Z1 pictured earlier in this thread.
Good Luck!
Exhaust Clamps
Good Luck!
Last edit: 20 Mar 2008 12:34 by Patton.
- 79MKII
- Love Them Kaws!
20 Mar 2008 12:36
Wow, that redline link says it all!!
The Kaw List:
- squints
25 Apr 2008 15:47
-Sidenote-
When I first got the VH system I read that they sometimes do not fit together correctly, as was the case when mine arrived. so I followed the suggestion here to bring it to a shop so they can expand the pipe a bit. I did this and the dudes told me not to bother, that its so close that it should fit with a little WD and some very minor burr removal. I say ok and put the exhaust back in the trunk of the car. Get home to try the suggestion of cleaning the connections and (note that the exhaust is pretty warm from being in the trunk) on a whim try to put the thing together without filing the burrs.
mmmmmmmmm, like a glove.
must have been that little warmth that expanded the metal and made it fit oh so right.
now i just have to get it apart to install on the bike...:S
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
Upstate NY
- leakyseal
- KZ pilot for life.
25 Apr 2008 16:34
i have a V&H on my 78'kz650 and it sounds awesome.Kerkers are nice,but i can't imagine it sounding better than your V&H.
- 2M4Dale
25 Apr 2008 17:42 - 25 Apr 2008 17:46
leakyseal wrote:
Yep, I love the way my V&H sounds ! I am wondering though about how it would sound with no packing ??? How much louder ??? I think this is a decent pic of my new pipes !!!
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
1980 KZ750H1 LTD
1981 KZ750H2 LTD
Last edit: 25 Apr 2008 17:46 by 2M4Dale.
