Took top off
  • sf4t7
  • sf4t7's Avatar
Re: Took top off
31 Oct 2025 05:21 - 31 Oct 2025 05:41
#918546
Hey - who you calling a gentleman??  I think I'm offended!
When you tried to rotate the crank, it may be the piece of ring jammed, but it's more likely that the chain wasn't taut and it doubled on itself and bound up.  Be careful when rotating with a loose chain - hold it up and tight to the crank sprocket.  (Don't ask me how I know, haha)
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 31 Oct 2025 05:41 by sf4t7.
  • lovethemkzs
  • lovethemkzs's Avatar Topic Author
Re: Took top off
31 Oct 2025 08:36 - 31 Oct 2025 08:38
#918553
Okay I went through all the speedy dry This morning And I checked it saved it with a magnet nothing
 I rotated the crank while blowing compressed air into the block nothing
 I also started draining the oil sifting it through a t-shirt into another container that's going to take a while but I went through the tub that I had it in with a magnet and it didn't pick up nothing
 so I took the bore and I put a full ring in one of them and the ring that I'm estimating I'm missing a piece and another I'll give you the pictures in a second
about 5-6 years ago before I bought this somewhere down in Allentown they did work on this bike and the guy sold it to 100 dealership and that's where I bought it from they had an oil leak been from the valve cover and when I drop the pan on this one I found it was all gritty the oil and I found the head of the zip tie down in the pan so my question is you think they just did s***** working put a s***** ring in or I'm missing a piece here's the pictures
Last edit: 31 Oct 2025 08:38 by lovethemkzs.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Took top off
31 Oct 2025 09:07
#918554
Pic is blurred of the suspect but the ends look square ? Does it feel like a piece broke off ?
  • lovethemkzs
Re: Took top off
31 Oct 2025 09:38
#918555
I got somebody hanging the gutter real quick a small piece I'm going to go back to the garage and take new pictures and I'm going to feel the edge and see if it's a squared Edge or a bent broken Edge
  • lovethemkzs
Re: Took top off
31 Oct 2025 10:01
#918557
Well wookie it looks like one end is smooth and the other three ends are jagged the one that meets up with the smooth end is Twisted feels a little Sharp the piece that's missing is no more than a quarter inch to 3/8 of an inch long it's very small but that's still can do a lot of damage huh
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • lovethemkzs
Re: Took top off
31 Oct 2025 11:15
#918559
Yeah it does hopefully it just went flying somewhere when I was taking off but I had to do my due diligence inside that engine but I'll let you guys know next year after I put it back together pray for me thanks for everything guys
  • lovethemkzs
Re: Took top off
08 Nov 2025 11:47
#918853
Okay I couldn't find the piece of ring that I lost I think it went flying because I lost two circlips on different occasions LOL I came back the next day I found the one under the bike and the second one I saw it fall in by the timing chain so what I did is I rotated the crank and timing chain about five six revolutions I blew it out with a high pressure hose nothing couldn't find it I went back next day with a flashlight and put a pair of glasses on and looking it was laying right on top of the timing chain if I grabbed it with a magnet and all it's good so after just finishing laughing my valves and put new valve guide seals I didn't change the valve guides but my question is I'm about ready to put it together I really don't want to use the old four O-rings that go between the Barrel and the head I look for a new set they want a $15 for each o-ring on my way must be mad so I'm going to look at Kawasaki owners and get the part number and see if I can find them made in Japan or something cheaper and any ideas where I can find them I'd rather not use the old ones
  • sf4t7
  • sf4t7's Avatar
Re: Took top off
08 Nov 2025 14:27
#918855
Are you talking about the 73mm orings around the cylinder liners where they go into the block?
If so Z1parts.net has them, $12.25 for the set of 4
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • lovethemkzs
Re: Took top off
08 Nov 2025 14:28
#918856
No the 18.5 mm 9 20-55- 1498 I believe it is oil port O-rings four is needed I'm finding them on Z1 Enterprise for $15 each $60 for four O-rings is crazy
  • sf4t7
  • sf4t7's Avatar
Re: Took top off
08 Nov 2025 14:39
#918858
If you have an old one, match it up at the hardware store, or if you can figure out the size, Mcmaster-carr.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • lovethemkzs
Re: Took top off
08 Nov 2025 15:10
#918859
I have all four of them wasn't sure about putting the old ones back in as they got a flat spot now from the Heat and I wasn't sure how good these other freaking O-rings are to stand up to the Heat I have an O reset and never tested checked it and see if it fit if I can match it I was just thinking that maybe they are more heat resilient than the standard o-ring
