Took top off
- lovethemkzs
Took top off
13 Oct 2025 18:59 - 14 Oct 2025 05:43
Okay I took the top half of the engine off I had a oil leak
I knew there was a problem with all the soot coming out from the reeds
no the barrel cylinders all are beautifully nice and smooth no scratches nothing the bottom of the piston looks brand new or I'm on all of them but the problem is I'm trying to figure out why I got so much carbon buildup on top of the Pistons I don't have a picture of the valves under the head but you can imagine what they look like by looking at these pictures of the Pistons
Last edit: 14 Oct 2025 05:43 by Street Fighter LTD.
- Warren3200gt
Re: Took top off
14 Oct 2025 00:56 - 14 Oct 2025 01:11
That's not at all bad. Looks pretty normal. If it were bad it'd be black and thick with soot.
Give it a decoke and reassemble.
Last edit: 14 Oct 2025 01:11 by Warren3200gt.
Re: Took top off
14 Oct 2025 04:38
Looks normal to me. Change your valve seals and clean things up.
- lovethemkzs
Re: Took top off
14 Oct 2025 07:02
I want to thank you guys I was worried but Benjamin ran great only a little oil leak was the problem and a little chattering under the valve covers I thought was tappets but I believe whoever reassembled it did not put the gaskets on the reeds and that I believe when they chatter is allowing Blow by back and getting all that soot but that's my opinion because when I took it apart there was no gaskets and the gasket kit came with a gasket for the reeds soThank you
now my plan was to relapse the valves clean them up put new rings on it and valve guides and valve guide seals anyway only real questions I got is how the Reeds go in which way do they open down or up because I believe something's wrong there too also I have to take it all the way down to nothing because when I disassembled it there were two washers missing from the head bolts and I think that's where the leak was coming from I know I didn't drop them in the engine but I have to check so I have to take all the way down to the crank I see if my magnets can pick up anything any suggestions how I can find out if I dropped anything down there
Re: Took top off
14 Oct 2025 07:28It's easy to throw money at these old girls but makes no sense to spend for the sake of it, diagnose and measure first (you will save a significant amount)I want to thank you guys I was worried but Benjamin ran great only a little oil leak was the problem and a little chattering under the valve covers I thought was tappets but I believe whoever reassembled it did not put the gaskets on the reeds and that I believe when they chatter is allowing Blow by back and getting all that soot but that's my opinion because when I took it apart there was no gaskets and the gasket kit came with a gasket for the reeds soThank you
now my plan was to relapse the valves clean them up put new rings Why new rings, if it wasn't smoking I would measure what you have before spending out on new) on it and valve guides (again why new guides - measure what you have) and valve guide seals Yes anyway only real questions I got is how the Reeds go in which way do they open down or up because I believe something's wrong there too also (unless you are really attached to an ineffective emission system there are several articles here on how to "delete" the reed valve set-up completely) I have to take it all the way down to nothing because when I disassembled it there were two washers missing from the head bolts and I think that's where the leak was coming from I know I didn't drop them in the engine but I have to check so I have to take all the way down to the crank I see if my magnets can pick up anything any suggestions how I can find out if I dropped anything down there Anything you dropped can only go down the chain tunnel, you can fish with a magnet on top of the crank and drop the oil pan off to find anything that made it past the crank
- moizeau
Re: Took top off
14 Oct 2025 09:29
The 'delete' was mentioned in your other post 'which way up' as was which way up it should be.
Like others have said, measure the wobble in the vlave guides, probably fine. Deffo change the seals, , use Viton ones. Yeah, lap the valves after a good clean, make sure you keep the valves in the same place they came from. Do a valve clearance check/reset while the head's off, set the clearances to max tolerance. Follow the book for putting it back together.
- lovethemkzs
Re: Took top off
14 Oct 2025 09:39
That was my plan to check everything clearances making sure they're within tolerance as far as deleting which way is up I don't know why they did that I'm just asking a question because that reads only go one way which the proper way for the air to circulate coming down from the top down into the cylinder or from the cylinder up back through the vent pipes to the air breather that's the only question I was asking
Re: Took top off
14 Oct 2025 10:59Air bleeds into the exhaust to dilute the tailpipe emissionsThat was my plan to check everything clearances making sure they're within tolerance as far as deleting which way is up I don't know why they did that I'm just asking a question because that reads only go one way which the proper way for the air to circulate coming down from the top down into the cylinder or from the cylinder up back through the vent pipes to the air breather that's the only question I was asking
Re: Took top off
14 Oct 2025 11:23
Reeds open downward into the cavity in the cam cover.
- lovethemkzs
Re: Took top off
14 Oct 2025 13:02
Thank you guys that's all I really need to know I think I'm okay from here I did bag everything and Mark it exhaust one intake one for the tap it stuff like that everything's going to go back to exactly how it came off but clean thank you again
- lovethemkzs
Re: Took top off
25 Oct 2025 19:04
I want to thank all you guys for all the help I got the bottom half together With new clutch pack And when I was Putting it together I noticed one ring on number Split in two
my question is should I just replace the one cylinders ring should I change all the rings and pistons because I feel if they were that brittle and snapped so so easily it might be a good time to change them all and how about the Pistons you can see when the previous pictures everybody said they're fine so just rings or just number ones ring that is broke
Re: Took top off
26 Oct 2025 00:25I would change all the rings (they will all have some degree of wear) just clean the pistons ( you can break an old ring to use as a tool to clean the "ring grooves" in the piston)I want to thank all you guys for all the help I got the bottom half together With new clutch pack And when I was Putting it together I noticed one ring on number Split in two
