no start after new rings - zephyr 550
  • TexasKZ
  • TexasKZ's Avatar
Re: no start after new rings - zephyr 550
07 Jun 2025 06:54
#913458
Did you try swopping the coil trigger wires left to right (the back firing suggests it's firing out of sequence)
This.
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
19 Jun 2025 17:47
#913881
Just a quick update. Tried swapping coils - no luck there.  I also did a leakdown test. Barely any leakage from any cylinders- maybe 2% with a tiny bit of air coming out of the crankcase. I was hoping to find something obvious...
If there is no leakage that also implies the cam timing is right, correct? I'm not sure what to try now. Maybe I should examine the reluctor wheel as per Daftfrusty's suggestion, though seems a long shot.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • Zaddict
21 Jun 2025 18:53
#913946
Man, half a step forward, ten steps back.
Today I opened her up again and reset the cams. I took the cams out, turned one revolution to TDC 1&4 again, and reinstalled the cams, #1 cylinder lobes facing outward.  This is in case I had the cams 180 degrees out, though I'm still not sure I understand how that could matter on these machines...
Tried to fire her up with no luck.  But then I took off the carbs, sprayed a little starter fluid in each cylinder, and then she'd start fine for a second at a time, pretty consistently.  So I was hopeful - maybe it's a fuel/carb issue after all (despite my near religious-levels of carb cleaning, never say never).
But then it's ten steps back. She sounded loud and rattly. I took out the automatic cam chain tensioner and installed a manual one.  By the time I got any tension at all on it, the engine would bind when I tried to turn it over by hand. I've installed manual tensioners before, that's very unexpected. I took out the manual tensioner and reinstalled the automatic one.  Same thing. I was able turn the engine over once or twice and then it just binds up. I took the valve cover off again and doublechecked timing - everything seems fine - no jumped links, lines all matching up . I went in with a flashlight to try to understand what's happening but didn't see anything obvious. Maybe the cam chain guide is loose or broken?  Any other ideas?
I'm pretty dejected - whatever it is I'll need to dig back deep into the engine...and even then I may be right where I started with the bike not starting...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
22 Jun 2025 12:44
#913956
When the motor binds, if you wind it backwards does it free off again. What you describe are symptoms of a shell bearing (crank or cam - I’m not familiar with this motor) turning with the crank or cam causing the lock up ????
  • Zaddict
23 Jun 2025 08:18
#913967
No, it doesn't seem to release if I wind it back.  However if I loosen the cam chain tensioner a bit I can turn over the engine again. So really seems it's interference with the tensioner and (?)something.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • hardrockminer
  • hardrockminer's Avatar
23 Jun 2025 14:38
#913975
I have never timed a 550 engine but I've timed a few 900's and 1000's and a couple of 650's.  When finished installing I always rotate the engine carefully to see if it will turn a complete rotation.  The problems I've had include the cam chain not on the crank sprocket correctly, two valves touching each other or a valve touching the piston.  I should add that whenever I set the cams in place the lobes on #4 exhaust and #4 intake were always pointing towards each other when #1 and #4 piston were at top dead center.
The following user(s) said Thank You: sf4t7, Gdizard
  • Zaddict
02 Nov 2025 19:36
#918644
Just to close the loop here, happy news! I put the carbs through an ultrasonic cleaner and reset the cams and timing. I had manually cleaned the carbs religiously 2-3 times, but the cleaning fluid was still filthy after the ultrasonic bath. Cams may have been off a tooth. Not sure it was the carbs or timing or a combo, but just put her back together, engine turned over just fine and she fired right up!!
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
The following user(s) said Thank You: Stereordinary, Wookie58
