no start after new rings - zephyr 550
- Zaddict
- Enjoying my Zaddiction!
31 May 2025 15:05
I bought a ZR550 parts bike a while ago, but it was in such good shape that I decided to try saving it. Despite having only 8,700 miles, it didn’t run—so I went for a full overhaul to start fresh.I honed the cylinders, installed new rings, and meticulously refurbished the carburetors using OEM float needles and set the fuel level per the FSM. I also did the usual maintenance: oil change, new battery, etc.Yesterday, I finally got everything back together… and it won’t start.It cranks fine and will occasionally fire up very briefly, but I can’t get it to keep running.
- Valve clearances are all in spec.
- Cam timing is set per the FSM at 1&4 TDC with #1 cam lobes pointing outwards.
- It’s getting spark at all four cylinders.
- Coil wiring is correct (green coil to 2&3, black to 1&4).
- Compression is solid: 124–127 psi across all cylinders.
- Scoped the cylinders—they look good. A bit shiny, probably from all the gas during repeated start attempts.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Re: no start after new rings - zephyr 550
01 Jun 2025 10:19
Cam timing 180 degrees out? It's easy to do (don't ask how I know).
The following user(s) said Thank You: Zaddict
- Zaddict
01 Jun 2025 10:49 - 01 Jun 2025 10:55
I mean, anything is possible. I did install them in this orientation at TDC for 1&4, with the #1 lobes pointing out (the pic is from Loudvx's kz550 Amazon page).
One thing I can be confident in is that the engine has compression. I'm seeing spark but maybe the spark timing is out, either because I have the cams installed 180 degrees out, or because there is a fault in the ignition system. I do have an spare ignition system I might try swapping that in. I'm 99% confident the carbs are clean (never say 100%) and it's getting fuel, but it's always possible they aren't. I'm wondering if I can try spraying some starter fluid into the airbox to check that aspect. Or do I remove the airbox and spray directly into the carb throats?
Frustrating but there must be a solution...
Edit: asked about swapping the 1&4 coil and 2&3 coils to address 180 degrees out cams but realized that wouldn't work
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Last edit: 01 Jun 2025 10:55 by Zaddict.
01 Jun 2025 11:49Edit: asked about swapping the 1&4 coil and 2&3 coils to address 180 degrees out cams but realized that wouldn't work
Try it.
- Zaddict
02 Jun 2025 08:27
Is it really possible for cams to be 180 out on these bikes given that it’s a wasted spark system? Like 1&4 and 2&3 get spark at the same time, so you’re going to get spark to the cylinder at the compression stroke even if it’s 180 off…
Looking more closely at the spark I noticed it’s yellow/orange. Apparently that’s the sign of a weak ignition system (I didn’t know - people say look for spark, not look for fat blue/white spark). Will dig in there next.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
02 Jun 2025 08:32
to be honest I would think if cam timing was more than even a "few teeth" out damage would occur !!
- Nerdy
02 Jun 2025 10:54Okay, perhaps we can get some clarification on this sentence.It cranks fine and will occasionally fire up very briefly, but I can’t get it to keep running.
How long is "very briefly"? When it does fire, does it run on all four? Does it backfire?
If it runs at all, I think we can rule out any egregious cam or ignition timing issues. You are correct the spark appears to be weak: check all ground connections and use a known good battery.
Also, try starting it in a dark room to see if the ignition wires are arcing/leaking.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Zaddict
02 Jun 2025 17:52Over maybe 4-5 straight minutes of cranking (over the course of a few hours) I'd say it ran for a total of maybe 20 seconds, but no more than 5 seconds at a time. When it would (rarely) start I scrambled to adjust the choke and idle screw to keep it alive but it would inevitably stall.Okay, perhaps we can get some clarification on this sentence.It cranks fine and will occasionally fire up very briefly, but I can’t get it to keep running.
Which grounds should I check? The coils I assume, and the ignitor ground. How is the engine grounded, through the motor mounts?
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- Nerdy
02 Jun 2025 18:11Which grounds should I check? The coils I assume, and the ignitor ground. How is the engine grounded, through the motor mounts?
All of them
I'd start with the main ground from the battery to the frame. Sometimes you'll find that even if the wire appears to be good, a lot of the individual strands will have snapped and only a few are left to provide a connection.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- Daftrusty
02 Jun 2025 18:28
There are ground points in the wiring harness, one of which is attached to a coil mounting point on the Zephyrs. There is also one in the harness that attaches to a bolt on the motor. The paint/coating on the motor mounts where they contact the engine can’t be trusted as a ground path.
You have gotten some very good advice, the only thing I might add is the reluctor wheel the ignition system uses is indexed to the crank by a very thin roll pin. If too much force is used turning the engine over by hand using the bolt on the reluctor wheel, it is easy to shear the roll pin, yet you will never know unless you remove the wheel to check. If the reluctor has spun on the crank, the ignition module will be firing the plugs out of time.
I can also add that if the electrical system for the starter circuit is weak and the motor turns over even slightly slower than normal, my zr550 will simply not start. It has to spin fast and have a fat spark for a cold start.
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
The following user(s) said Thank You: Zaddict, kimchella
- Zaddict
06 Jun 2025 17:06
Well, boo. I tried swapping out ignition components and am getting a fat spark across all cylinders, but still no joy. I couldn't even get it to start at all this time. Also, I noticed quite a bit of backfiring. Actually, pretty sure my entire neighborhood noticed the backfiring as it sounded like a shotgun blast at times.
I'll go back and recheck cam timing, not sure what else to try.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
07 Jun 2025 00:06
Did you try swopping the coil trigger wires left to right (the back firing suggests it's firing out of sequence)
