KZ750 Four Cam Install Help
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: KZ750 Four Cam Install Help
05 Jun 2025 12:27
#913396
Sounds promising, hopefully you are all good now :)
  • SnyperX
  • SnyperX's Avatar Topic Author
05 Jun 2025 13:18
#913398
Re-measured the valve clearances using @Nessism method. and am now on the higher end of the clearance numbers were before I was at the lower (minimum) number.
Valve Clearances as of 6/5/25 (mm)
Regards,
SnyperX
1981 KZ750H2 LTD
The following user(s) said Thank You: Nessism, Wookie58
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 Jun 2025 15:46
#913401
Looks like you have had a result :) I suspect the chain issue was down to incorrect timing, the valves must have been just kissing the pistons but because you were patient and only rotated by hand it looks like you have gotten away with it- there really is zero margin for error
well done
The following user(s) said Thank You: Kaw-boy 900
  • SnyperX
19 Jun 2025 19:02 - 20 Jun 2025 08:46
#913884
After checking the valve clearances again and re-checking the timing I buttoned up the top and fired her up this evening. I think she sounds great!!!
Regards,
SnyperX
1981 KZ750H2 LTD
Last edit: 20 Jun 2025 08:46 by SnyperX.
