KZ900 valve shims Machining
- Kaw-boy 900
- Let the Good ''Old'' Time Roll !
Re: KZ900 valve shims Machining
22 Mar 2025 06:48Running without a shim could leave those marks as well as damage the cam lobe.
No doubt...You're right, the shims were most likely dislodged from the bockets and the cam lobe has made those marks.
The head had to be replaced because no damage noticed . The cams look good...probably replaced too !
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
- Kaw-boy 900
22 Mar 2025 07:15 - 22 Mar 2025 07:20+1 on that.Running without a shim could leave those marks as well as damage the cam lobe.
That bucket has been run without a shim.
Most likely a ground shim shattered and was spat out.
I would advise replacing any buckets with that damage.
The indent /trough on the bucket caused by the cam will leave a void under the replacment shim which could also cause that one to fracture as well.
Thanks for the head ups ! I verified with my gauge and it is find and the shim move freely but I will order a new one anyway. Note: I have replaced the one with the tacks weld inside.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 22 Mar 2025 07:20 by Kaw-boy 900.
- zed1015
22 Mar 2025 07:28Yes!regarding shim buckets on the z900 i heard somehwere that on some z900 the buckets came with a void from factory that made shims crack.They was later replaced. Do you know anything about that ? and is it anyway to identify the buckets that is good ?
The early Z1 buckets had a small dimple in the center which caused the shims to crack and were subject of a service bulletin so they should have all gone in the dealers bin years ago..
Their replacements and subsequent buckets on all post Z1 engines just have a smooth plain surface with no indent and cause no problems.
The following user(s) said Thank You: asphalt900, MFP-Joe, Gdizard, Rolf1976_KZ900, kimchella
- Cra-z1
22 Mar 2025 09:44 - 22 Mar 2025 09:46
When I picked up my oct 72 Z1 9 (WITH 12,000 MILES) I was surprised to find it had the original buckets which I changed out with an engine rebuild.
Last edit: 22 Mar 2025 09:46 by Cra-z1.
22 Mar 2025 14:01The imprint on the bucket looks like some wanna be genius mechnic add a cut out thin sheet metal of a beer can to adjust the valve lash.The head and valves are back from the machine shop, Sterms, springs retainers and keepers trimmed. Valves shims are 2.70 - 2.80 Ex and 2.55 - 260 mm. (2 of each from Zi Entreprises set) I'm happy with the results. Now waiting for new valve seals.
It look like the previous owner or his mechanic had issue with thin shim ! There is 2 bucket like this. What else can make this kind of marks ?
The following user(s) said Thank You: Kaw-boy 900
- Kaw-boy 900
22 Mar 2025 14:17 - 22 Mar 2025 14:40The imprint on the bucket looks like some wanna be genius mechnic add a cut out thin sheet metal of a beer can to adjust the valve lash.
Let me measure it...wont surprised me at this point...LOL.
The sharp gauges around the external perimeter make me belived that was caused byt a FU*King machined shim cracked and /or spilled out of his nest ! I can imagine the rest of the story,...wrong valves keeper got out, valve hit the piston then kick out the bucket shim and a ''NOT' funny noised happened ! Look that it happened at start up....my 2 cents !
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 22 Mar 2025 14:40 by Kaw-boy 900.
- zed1015
22 Mar 2025 15:46The gouges around the perimeter of the bucket were caused by the edges of the cam lobe once the shim had gone and without the shim the cam lobe also wears a groove on the bucket surface.The sharp gauges around the external perimeter make me belived that was caused byt a FU*King machined shim cracked and /or spilled out of his nest !
If you measure the width of the imprint you will find it matches the width of the cam lobe..
- Kaw-boy 900
22 Mar 2025 16:16 - 22 Mar 2025 16:23
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 22 Mar 2025 16:23 by Kaw-boy 900.
22 Mar 2025 16:55
There is no more sickening sound than "mechanical love making
The following user(s) said Thank You: sf4t7, Rolf1976_KZ900, Kaw-boy 900
- Cra-z1
22 Mar 2025 20:31
Whatever shop worked on that engine should be shut down
The following user(s) said Thank You: Gdizard, Wookie58, Rolf1976_KZ900
- zed1015
23 Mar 2025 03:26No problem using that cam.
I'd just dress back the chipped edges to remove the sharp edges and any loose chips and it's good to go.
23 Mar 2025 06:14
I wonder how many cam chips and loose pieces of shattered shims are still floating around inside that engine?
The following user(s) said Thank You: MFP-Joe, Gdizard
