KZ400 Exhaust Swap
  • ThatYeti
  • ThatYeti's Avatar Topic Author
KZ400 Exhaust Swap
17 Sep 2024 18:51
#904404
Finally managed to find a used original exhaust for my bike to replace the super loud franken exhaust that it came to me with, after having zero success quieting it down with different replacement baffles.
Question now is what all I might need to swap in the new pipes. Do I need to replace any gaskets? Any tips on getting the old pipes off the studs without breaking anything? And are the pipes I got the style that caused oil leaks due to the crossover pipe? If so should I cap those off?
Looking to swap everything all at once so if I need more than the missing clamp for the crossover pipe I want to order it ahead of time.
Thanks as always
'76 KZ400
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: KZ400 Exhaust Swap
18 Sep 2024 02:06
#904420
You should replace the gaskets between the pipe and cylinder head, you can use a small amount of exhaust sealer on the balance pipe. With the studs you should soak them with penetrating fluid and repeat over a couple of days (not when hot as penetrating fluid is flammable) when removing the nuts - if they go tight wind them back on and clean the stud with a wire brush, apply penetrating fluid and wind off again (keep repeating this process until the nuts are off)
The following user(s) said Thank You: ThatYeti
  • ThatYeti
18 Sep 2024 04:06
#904421
Thanks, I'll see about finding gaskets along with the metal clamp, but there's nothing I needed to worry about in keeping that crossover pipe?
'76 KZ400
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Sep 2024 04:37
#904422
Not that I am aware of
  • ThatYeti
18 Sep 2024 05:31
#904424
Any idea which gaskets are a better option? Seeing both aluminum and copper gaskets in searching, mostly seeing them on eBay and oddly seeing both in OEM packaging.
'76 KZ400
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Sep 2024 05:35
#904425
I will leave that for the 400 guys on here to share their experience, what part number does CMNSL or Partzilla list for your specific bike ?
  • ThatYeti
18 Sep 2024 07:36
#904427
Partzilla doesn't have anything for it and the only one I found at a retailer was Z1 who shows it out of stock but it's the aluminum gaskets with part number OEM Ref: 11060-1242
'76 KZ400
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
18 Sep 2024 10:31
#904430
According to Kawasaki site the exhaust pipes for the 76 and 77 models did not have the cross over pipe, but it does show this pipe for the 78 model year.  Which does show the clamps and gaskets it used.  www.kawasaki.com/en-us/owner-center/parts/142603/1978/KZ400-B1
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: ThatGPzGuy, ThatYeti
  • ThatYeti
18 Sep 2024 11:27
#904431
Guess the new to me exhaust must be from a slightly newer bike, but holding it up to the pipes on it seems like it'll fit just fine. Do I need to worry about that crossover pipe? Saw an old post talking about how an early version that seemed to run through the engine caused leaks. This one seems like it would run underneath but I guess I could see about welding those holes shut if it'll be problematic.
'76 KZ400
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Sep 2024 13:00
#904432
I believe what you are referring to was a passage in the head (happy to be corrected) the balance pipe in the exhaust helps torque and smooth running by balancing both cylinders - I'm not aware of any downside (probably why the factory fitted it on later models)
  • ThatYeti
19 Sep 2024 04:11
#904447
Any opinions on whether the copper or aluminum gaskets (crush washers) are the way to go? And any idea if one meant for a car would work, so long as it's the right size? Was hoping to get the exhaust on soonish but if I have to order the washers it looks like it's going to be weeks before I'll get them.
'76 KZ400
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
19 Sep 2024 04:48
#904449
Cars don't use this type of sealing washer, personally I think either aluminium or copper (which ever is easily available) should do the trick (it simply needs to crush and fill any gaps between the header and exhaust port)
