- Thank you received: 2059
German Made Aluminum Cam-End Plugs
04 Jul 2024 15:35 #901759
by Scirocco
Replied by Scirocco on topic German Made Aluminum Cam-End Plugs
E-mail send Wookie.
- slmjim+Z1BEBE
- Thank you received: 732
05 Jul 2024 05:17 #901767
by slmjim+Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Replied by slmjim+Z1BEBE on topic German Made Aluminum Cam-End Plugs
If anyone's really interested, we have a NOS set of cam end plugs that have the vertical holes in them that fit... something. They're in the original blister pack. APE, maybe; don't remember. Pretty sure they're clear anodized. They're packed away right now in one of the storage bins of parts we're taking to to Mid-Ohio this year. We'll glance around, root a little bit & see if maybe they're on top in a bin or easily visible. Otherwise, we'll be unpacking the bins at the end of this month at the swap meet.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- z1kzonly
- Thank you received: 537
05 Jul 2024 10:36 #901781
by z1kzonly
Replied by z1kzonly on topic German Made Aluminum Cam-End Plugs
DV-o! That motorcycle is cleaner than my lady's bathroom!!!
The one she won't let me use!
I always enjoyed looking at it. Though, I never got into the later post 80 models.
Yours is the best I've seen! OEM with a touch of Class!
The "Gunsbluemoon" Seller started making CNC billet parts 20? years ago!
He started making cam chain tensioners and Z1 cam plugs then.
An Excellent machinist! He is!
I purchased his parts then!
Marty in Buffalo
Marty in Buffalo
- sf4t7
- Thank you received: 348
05 Jul 2024 14:03 #901795
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replied by sf4t7 on topic German Made Aluminum Cam-End Plugs
I also purchased some of Gunsbluemoon's cam end plugs and they fit perfectly.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- daveo
- Thank you received: 654
05 Jul 2024 18:19 - 05 Jul 2024 18:48 #901802
by daveo
1982 KZ1100-A2
Replied by daveo on topic German Made Aluminum Cam-End Plugs
1982 KZ1100-A2
Last edit: 05 Jul 2024 18:48 by daveo.
- daveo
06 Jul 2024 00:44 - 06 Jul 2024 00:49 #901808
by daveo
Done my best to maintain the stock "sleeper" KZ1100A appearance, always trying to attract minimal attention...
Gladly sadly, her noise gives that away.
photos.app.goo.gl/6or9nh7us5B5vXp1A
1982 KZ1100-A2
Marty in Buffalo
1982 KZ1100-A2
Last edit: 06 Jul 2024 00:49 by daveo.
- Thank you received: 2224
06 Jul 2024 09:16 #901821
by TexasKZ
Replied by TexasKZ on topic German Made Aluminum Cam-End Plugs
Nice sounding bike.
I do miss church bells.
- asphalt900
- Thank you received: 274
06 Jul 2024 09:48 #901823
by asphalt900
Replied by asphalt900 on topic German Made Aluminum Cam-End Plugs
Call me silly but why would one want to divert to "solid" end-plugs?? They utilized the rubber and shiny blocked cover for a reason and worked super well for years in operation. You'll miss out on rubber sealing that naturally comes with the original design, especially where the M6 bolt passes thru.
- daveo
06 Jul 2024 12:54 #901826
by daveo
1982 KZ1100-A2
I've had oil weeping issues with the metal-faced rubber plugs on past cylinder head installations. The solid plugs minimize and potentially eliminate that, which also means fewer expensive cam cover gasket replacements.
1982 KZ1100-A2
- Thank you received: 2738
06 Jul 2024 13:10 #901828
by SWest
Replied by SWest on topic German Made Aluminum Cam-End Plugs
YUPI've had oil weeping issues with the metal-faced rubber plugs on past cylinder head installations. The solid plugs minimize and potentially eliminate that, which also means fewer expensive cam cover gasket replacements.
06 Jul 2024 14:04 #901831
by Scirocco
The pure aluminum cam end caps made the cyl. head like a one pice casting unit.
Rubber can shrink or dry out, so weeping or a mist of oil could your future problem you have to fix with money, time and labor.
Just my 2 cents
Just my 2 cents
The following user(s) said Thank You: daveo, SWest
11 Jul 2024 03:56 #902000
by Scirocco
