- Thank you received: 2059
Oil light?!
15 Jun 2024 14:33 - 15 Jun 2024 14:38 #900768
by Scirocco
Replied by Scirocco on topic Oil light?!
Only use motor oil with JASO MA standard (Japanese Automotive Standards Organisation)
without anti-friction additives for engines with a wet clutch.in the engine case.
These additives let the clutch slip at max power and/or acceleration.
Cars have a dry clutch seperated form the crank case (engine oil) so can use anti-friction aditives.
Last edit: 15 Jun 2024 14:38 by Scirocco.
- Maxbou92
- Thank you received: 4
15 Jun 2024 15:50 #900770
by Maxbou92
Kz750e 1980
Replied by Maxbou92 on topic Oil light?!
Yes I guess its the oil that cause my clutch slipping so muuuuch and not the clutch. Do you think that I ruin the clutch with that oil? I’ve don’t let the clutch slip when it was happen!!
Kz750e 1980
- F64
- 81-KZ440D2
- Thank you received: 394
15 Jun 2024 16:08 - 15 Jun 2024 16:16 #900771
by F64
81-KZ440-D2.
LIC, NY
Replied by F64 on topic Oil light?!
Ehhhhhh you probably didn't ruin the clutch but it does heat it up a lot because it's slipping.
It really depends on how much you slipped your clutch.
I would change your oil and filter.
Just in case anyone who is curious. Here's the current monthly list of JASO oils.
Shell has not been on the list but that doesn't mean they aren't JASO.
Which means the list may be incomplete and you should do your own research in addition.
www.jalos.or.jp/onfile/pdf/4T_EV_LIST.pdf
And here's more info on the differences between JASO MA, JASO MA1, JASO MA2, JASO MB
www.mototribology.com/articles/jaso-explained-part-1
81-KZ440-D2.
LIC, NY
Last edit: 15 Jun 2024 16:16 by F64.
- Maxbou92
15 Jun 2024 16:57 #900773
by Maxbou92
Kz750e 1980
Thank youu man!! For my oil light, it is ON even the bike is not running. So today I take it for a 30km run and the engine is running like a new one. My conclusion is that’s a electrical problem..
Kz750e 1980
- F64
- 81-KZ440D2
15 Jun 2024 19:18 - 15 Jun 2024 22:36 #900776
by F64
81-KZ440-D2.
LIC, NY
The light is supposed to be on when the bike isn't running and the key switch is on.
You have no oil pressure!
oh well
oh well
81-KZ440-D2.
LIC, NY
Last edit: 15 Jun 2024 22:36 by F64.
- Thank you received: 1656
16 Jun 2024 08:12 - 16 Jun 2024 08:21 #900800
by martin_csr
Replied by martin_csr on topic Oil light?!
Um, did you actually check anything? The stuff mentioned? It's kind of foolish to ride around with a glitchy oil light.
The warning light should come on when the ignition switch is turned to ON. And it should stay ON until you start the engine.
Kind of related and your oil light problem could be this simple. My neutral switch was glitchy, so I removed the engine/sprocket cover and cleaned up the connection and crimped the terminal a little for a tighter fit. problem solved.
Last edit: 16 Jun 2024 08:21 by martin_csr.
- JR
- Thank you received: 445
16 Jun 2024 08:17 #900803
by JR
Replied by JR on topic Oil light?!
It's really easy to check and potentially catastrophic if you dont.
The following user(s) said Thank You: slmjim+Z1BEBE, SWest, Wookie58
- Thank you received: 2301
16 Jun 2024 08:25 #900806
by Wookie58
Replied by Wookie58 on topic Oil light?!
30km with unknown oil pressure !!!!!!!!!!!!!!!!!!!!!! I guess that's one way to establish the problem is electrical oil pressure check would have been preferable to "blowing the crank" which would have established a mechanical faultThank youu man!! For my oil light, it is ON even the bike is not running. So today I take it for a 30km run and the engine is running like a new one. My conclusion is that’s a electrical problem..
- ckahleer
- Thank you received: 143
16 Jun 2024 08:55 #900809
by ckahleer
94 KE100
81 CM200t
82 KZ305
85 VF1100c
Replied by ckahleer on topic Oil light?!
Stop it! You guys are scaring me. I ride around all the time on my kz305 that dosn't have an oil light. Maybe because it was a cheap bike, Kawasaki didn't want to spend the bucks.
94 KE100
81 CM200t
82 KZ305
85 VF1100c
- Thank you received: 2738
16 Jun 2024 09:30 #900812
by SWest
Replied by SWest on topic Oil light?!
My 350 Honda had a bolt on the head to test oil pressure. No oil filter just a spinning drum to catch particles. You had to clean it each oil change. Beyond that it was a great bike.
- Maxbou92
16 Jun 2024 12:12 #900814
by Maxbou92
Kz750e 1980
I have clean the neutral switch near front sprocket. And light is still on.. I just make a ride of 100km again!! Like a brand new!! Fucking oil light !! I will check the pressure oil switch tonight. Bad wire?! Thank youuu everyone I appreciate
Kz750e 1980
16 Jun 2024 15:44 #900818
by martin_csr
I have clean the neutral switch near front sprocket. And light is still on...
Oops. We seem to have a communications problem.
The neutral light has nothing to do with the oil light.
Fixing my neutral switch electrical connection was easy >> I was saying maybe fixing your oil switch electrical connection might be easy too. You need to start checking stuff. I would check the oil switch first >> first thing is to make sure the electrical connection is good >> very easy to check.
