Help needed with Pipe Exhaust for Z750 L2
- thanos12
29 Sep 2023 23:35
Can anyone provide the part number of #3 (Right) Exhaust Pipe for my Z750 L2 ? I have lost the manual
Probably would start with 18049-
I know that the L3 and L4 model have the same part number 18049-1163.
Does anyone has the part manual from L2 to verify it?
Thanks in advance!
Thanks in advance!
Re: Help needed with Pipe Exhaust for Z750 L2
30 Sep 2023 05:43
L2-L4 should be the same. Also, same as R1, only that exhaust is black.
And regarding the inner headers for #2 & #3, it seems that they are all the same across all the KZ750/4 family of bikes. That should help you expand your search.
- thanos12
30 Sep 2023 10:38
The L3-L4 have printed mark E005 concerning the emissions. The L2 has E004. So I would like to confirm from someone who has the manual within his hands. Thanks for replying.
- gd4now
- Denco where did you go?
30 Sep 2023 11:13
I do not have a manual for the L2, but do have this link for parts list for the L3. Not sure if it will provide any help or not but here it is.
kz.bike-night.com/parts/C-10Mufflers.jpg
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- thanos12
30 Sep 2023 11:27
Thanks for the info again but I need it from L2 manual. Look also the differences (image attached).
30 Sep 2023 11:27 - 30 Sep 2023 11:28
Cmsnl.com in the UK may have diagrams for your motorcycle with part numbers. But there won't be any emissions info.
Last edit: 30 Sep 2023 11:28 by martin_csr.
- thanos12
30 Sep 2023 11:29
They do NOT have for L2. I have already searched. Generally my question was very specific after hours of research. I need someone with L2 manual. Thanks for your thought!
30 Sep 2023 11:38 - 30 Sep 2023 11:48
Any emmision banding for an exhaust will be for the complete system, if the bends and dimensions are the same the alternatives suggested should work (it's only a peice of pipe at the end of the day with nothing about it that will effect emissions)
CMNSL list 180491163 for the following
L3 - 1983
H - 1981
E1 - E2 - E3 1981-1983
I am sure there's more but I got bored, it appears that as Nessism said this is a pretty generic part. Given that the listed fitments are both older and newer than yours I think you are "over thinking it" but that's only my opinion
L3 - 1983
H - 1981
Last edit: 30 Sep 2023 11:48 by Wookie58.
- thanos12
30 Sep 2023 11:41
I am completing restoring it and due to a flood I lost the manual! I am almost at 95% percent. I saw the forum and I just hit the question if anyone has it. Now if anyone has it please a take a photo or just reply with part number. Thank you.
30 Sep 2023 12:13If you are going for 100 point "correct" restoration then I understand your desire to get a part with the correct stamping so disregard my last post if this is the caseI am completing restoring it and due to a flood I lost the manual! I am almost at 95% percent. I saw the forum and I just hit the question if anyone has it. Now if anyone has it please a take a photo or just reply with part number. Thank you.
30 Sep 2023 13:24
Good luck with your search. I can find a few different pipes on eBay USA, but photos show E005. Bummer. To my knowledge, the pipes aren't marked with a PN, so there is that complication also.
- thanos12
30 Sep 2023 13:31
I have made the same research. I will wait an owner to post his L2 manual!
