New Cam End Plugs
- Cra-z1
Re: New Cam End Plugs
01 Aug 2023 16:57
I also use the aluminum plugs, black for the 73 and silver for the later bikes. I found you need to file the ends of the head down just a bit so those plugs fit perfect. On some heads the lower portion of the half moon on the head is a little thicker than the plug. Not a big deal. But once they are there they will not blow out.
The following user(s) said Thank You: slmjim+Z1BEBE, SWest
01 Aug 2023 17:12
- MLMG
- See you in the wind.
06 Aug 2025 13:46
Hi, where did you buy that windshield?
1977 Kawasaki KZ1000 A1
