Cam wear
Re: Cam wear
10 May 2023 11:55
Close up of the lobes would help.
Re: Cam wear
10 May 2023 13:03
What model is your 82, J-K-M or P ?
- blipco
- 2002 KZ1000P
Re: Cam wear
10 May 2023 13:51 - 10 May 2023 13:52
Thanks for posting the pics. The lobes don’t look that bad by my eye, I wouldn’t have thought to measure. Somebody please point out something that would have tipped me off.
I have a ZRX which is well known for having cam lobes which wear through the case hardening in places at very low miles. You can see the cast iron in the holes. But they seem to stop wearing any further by 20 - 30 thousand miles. The wear doesn’t cause any issues outside of crapping your pants the first time you see it.
Last edit: 10 May 2023 13:52 by blipco.
Re: Cam wear
10 May 2023 14:15
I have to say (IMHO) I think those lobes don't look to have worn nearly a full millimetre. I would have expected them to be dull not shiney as they would have been well and truly worn through the hardening ?
- timewaster
Re: Cam wear
10 May 2023 15:26 - 10 May 2023 15:31
The camshafts in that picture are from a KZ1000K, LTD, so they are still within spec.
See page 6-19 in the fsm for how to identify the camshafts.
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
You can check the frame and engine numbers here—
www.kzrider.com/filebase?task=download.s...id=1178&catid=64&m=0
Last edit: 10 May 2023 15:31 by TexasKZ.
The following user(s) said Thank You: Nessism, Mikaw
- timewaster
Re: Cam wear
12 May 2023 12:06
Thanks for that. I've been under the impression since I got it that it was a J. The table that you published confirmed that it was indeed a K. Looking at that information, the lobe that is worn most worn is still barely in spec.
Just out of curiosity, how were you able to tell by looking at the cams?
Many thanks, that will make things easier from here on out.
- blipco
- 2002 KZ1000P
Re: Cam wear
12 May 2023 13:42
To me, from the pics you posted, the cam lobes look fine. They looked like any cam I have ever seen in an engine.
Oil starved or otherwise damaged cams look it.
Re: Cam wear
12 May 2023 14:51See page 6-19 in he fsm for camshaft identification.Thanks for that. I've been under the impression since I got it that it was a J. The table that you published confirmed that it was indeed a K. Looking at that information, the lobe that is worn most worn is still barely in spec.
