oil cooler thermostat
- Fox
25 Apr 2023 08:41 - 25 Apr 2023 08:49
Hello,
to instal an oil cooler thermostat i need to connect the "engine in" of the thermostat to the hose from the oil pump.
(where oil will come to the thermostat) What is the good one please ?
The bottom left one ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 25 Apr 2023 08:49 by Street Fighter LTD.
Re: oil cooler thermostat
25 Apr 2023 08:52
Yes, the bottom left with the switch in it
The following user(s) said Thank You: Fox
- Fox
25 Apr 2023 13:28 - 25 Apr 2023 14:04
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 25 Apr 2023 14:04 by Street Fighter LTD.
25 Apr 2023 13:56
Do you really need a oil cooler thermosstat?
The following user(s) said Thank You: Warren3200gt
- Injected
25 Apr 2023 13:57
The line from the switch port is from the oil pump to the cooler, the other line returns oil from the cooler to the cylinder head.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- Fox
25 Apr 2023 14:23
Hello. The themostat yes i need it.
The oil cooler not really . But it will preserve the engine for longevity of the parts.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Warren3200gt
25 Apr 2023 14:33
Do you mean thermostat or do you mean temp guage?
If you put a thermostat in the oil feed line surely the head will be starved of oil until the gearbox oil temp reaches high enough for the thermostat to open and allow flow or am I misunderstanding something.?
The following user(s) said Thank You: Scirocco, hardrockminer
25 Apr 2023 15:11 - 25 Apr 2023 15:24
The oil cooler thermostat valve divided,bypass and resticted the oil flow in two diffrent oil feeding circles like on water cooled engines.
So a oil cooler is a must have or you cut off the oil flow on a hot engine!
Last edit: 25 Apr 2023 15:24 by Scirocco.
- zed1015
25 Apr 2023 15:32 - 25 Apr 2023 15:33If you don't need a cooler you don't need a thermostat and if you are in a mostly hot climate you can run the cooler without a thermostat.Hello. The themostat yes i need it.
Last edit: 25 Apr 2023 15:33 by zed1015.
The following user(s) said Thank You: slmjim+Z1BEBE, Scirocco
25 Apr 2023 15:54 - 25 Apr 2023 16:00The thermostat simply takes the cooler out of the circuit until it is needed, you still get full flow to the head but a small amount is diverted through the cooler to avoid " cold shocking" the system when the thermostat opens (same as a coolant thermostat on a water cooled motor which takes the radiator out of circuit until operating temp is reached)Do you mean thermostat or do you mean temp guage?
Last edit: 25 Apr 2023 16:00 by Wookie58.
25 Apr 2023 15:59Surely if the need for a cooler is borderline (like here in the UK where we get one hot week a year !) then it's better to have it and not need it than to need it and not have it ? At least with a thermostat you aren't "over cooling" and if it's required it will take care of itself.If you don't need a cooler you don't need a thermostat and if you are in a mostly hot climate you can run the cooler without a thermostat.Hello. The themostat yes i need it.
25 Apr 2023 16:00
I run my oil cooler without an oil cooler thermostat, never had any problems!
The following user(s) said Thank You: SWest, Mikaw, Warren3200gt, Wookie58
