Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 13:33 #881989
  • DanMadBoy
  • DanMadBoy's Avatar Topic Author
  • User is blocked
  • Thank you received: 14
I noticed a little bit of flaky rust in my KZ750 Tank.
Evaporust arrives today via Amazon. I have a water distiller at home (I havent drunk tap water for over 10 years - dont eat red meat either, but I digress..) and plan to wash the tank with it after emptying the Evaporust.
I also bought WD40 corrision inhibitor spray, but wonder if there is a better way to stop the almost instant flash rust that occurs?
Last edit: by DanMadBoy.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 14:03 #881991
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2678
Try the search function.  This topic has been discussed many times.
BTW, that WD-40 stuff is the wrong stuff.  Regular WD-40, in large quantity, would be more appropriate.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 14:14 #881992
  • DanMadBoy
  • User is blocked
I called WD-40 makers and they said, in the case of preventing tank flash rust, this works BETTER than their regular stuff. Im using it.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 15:00 #881994
  • urankjj
  • urankjj's Avatar
  • Thank you received: 201
Prior to moving my KZ cross country here in the U.S., I had to drain the fuel tank and was quite concerned with flash rust that might occur with the fluctuating humidity. The only thing I had on hand was a can of  Remington "Rem Oil" gun lubricant spray. I fogged the inside of the tank liberally and had no issues at all with flash or surface rust, even today, a yr a half later.  Don't get rusty.....
Last edit: by urankjj.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 15:24 #881995
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1468
No special potions needed.
Once cleaned out just fit and fill the tank with fuel asap and keep it topped up.
If the tank is going to sit empty a while then simply pour in some thin oil and rotate the tank until the inside is coated.
Both tried and trusted, simple and effective methods that have served many well since the invention of the motorcycle.
Last edit: by zed1015.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 16:03 #881996
  • Nessism
  • Nessism's Avatar
  • Away
Evaporust needs to be water rinsed, and that's when the flash rusting occurs.  I'm not so sure about putting gas in the tank unless it's dry, unless you are going to use the gas to flush out any water, and if so, there are better products.
I use alcohol right after the water rinse, dump it out, then hit the tank with WD-40, and compressed air.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 16:17 #881997
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 353
I just used some Bel Ray 2 stroke oil.
You may want to fill it up with high octane if you do this.
I've heard the oil will lower the octane rating.
81-KZ440-D2.
LIC, NY
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 16:18 #881998
  • Nessism
  • Nessism's Avatar
  • Away
Why did you post this thread?
The following user(s) said Thank You: ronnieV, SWest, Warren3200gt
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 16:27 #881999
  • DanMadBoy
  • User is blocked
Awesome. Thanks for this.
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 16:28 #882000
  • DanMadBoy
  • User is blocked
Super helpful! Thanks a lot!
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 16:36 #882001
  • DanMadBoy
  • User is blocked
Just did some research and this stuff is highly regarded, so I will be using this. Thanks so much! I learned something new today!
Flash Rust post Evaporust KZ Tank: PICS 25 Mar 2023 23:45 #882006
  • Ojisan rider
  • Ojisan rider's Avatar
  • Thank you received: 63
You going through all these trouble to clean the tank. You don't want to seal it?
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
