am I correct, the valve doesn't rotate generally?
  • Gdailey2112
  • Topic Author
  • 82 KZ1100D1
04 Oct 2022 19:19 #875057 by Gdailey2112
this is my question, do the valves rotate in the guide? i mean unlike that of old flat tappet car engine but even that just spins the lifters and not the valves, correct?
1982 KZ1100D1
04 Oct 2022 19:35 #875058 by Togoster
I can’t see where there is a spin induced but nor is there anything that would stop some rotational movement.Guess you have to be there.
Get your motor running!
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • Topic Author
  • 82 KZ1100D1
04 Oct 2022 19:55 #875061 by Gdailey2112
Replied by Gdailey2112 on topic am I correct, the valve doesn't rotate generally?
agree, but surely someone knows whether it'd be considered common or not.
maybe i smoked one eye closed and couldn't see outta the other LOL
1982 KZ1100D1
  • SWest
  • 10 22 2014
04 Oct 2022 20:12 #875063 by SWest
04 Oct 2022 20:21 #875064 by Irish Yobbo
Replied by Irish Yobbo on topic am I correct, the valve doesn't rotate generally?
Valves do rotate in normal operation. There are some vids online showing this .
As I understand it, the compression of the spring tends to turn the valve in one direction, and the decompression turns it back. But since it's under more force during compression due to inertia, the compression rotation 'wins out'. I've also read that the rocker arms can be set slightly off-centre on the valve to turn the valve as it pushes down, but I've never measured. But don't quote me on this. Suffice to say - the valves will rotate in normal operation on most engines.
Some engines use a mechanism to ensure rotation using a ball and ramp system, similar to a starter clutch. I would guess this is to introduce more rotation than is exerted by the springs.
1981 KZ750 LTD
The following user(s) said Thank You: SWest, Gdailey2112
05 Oct 2022 01:01 #875069 by blackozvet
Replied by blackozvet on topic am I correct, the valve doesn't rotate generally?
Valves can rotate - usually at higher rpm.
over the years some engines have been designed to ensure the exhaust valves rotate to keep the seats clean.
if you do some research on Youtube you can find some interesting stuff - especially videos inside an engine of the valve train at high rpm - it looks really scary !
1973 Z1 900 Kawasaki
  • Scirocco
  • Premium Member
05 Oct 2022 01:10 #875071 by Scirocco
Valves do rotate on higher rpm!
05 Oct 2022 04:26 #875072 by Wookie58
  • Gdailey2112
  • Topic Author
  • 82 KZ1100D1
05 Oct 2022 11:38 #875102 by Gdailey2112
yes sir that's the information I was seeking.
and the double springs are to thwart floating the valves at high rpm?
what's the best tool for measuring when checking your valve tipping length (for the DIY's) I have a 6" dial caliper but not sure if that'll suffice or maybe there is something better?
1982 KZ1100D1
05 Oct 2022 12:13 - 05 Oct 2022 12:16 #875105 by zed1015
You need to take the installed height measurement from the valve tip to the bare head with the steel spring seat removed.
If the valve is stock then you can take off 0.30 mm .
Any more and you can trim the collets and retainers if they are shim on top by a max of 1mm.
A vernier depth gauge can be used but that is tricky and can give inconsitent results even for the non diy-er.
A height gauge as in the pic of the correct minimum length is the only way to get reliable readings.
Last edit: 05 Oct 2022 12:16 by zed1015.
  • Gdailey2112
  • Topic Author
  • 82 KZ1100D1
05 Oct 2022 22:37 #875140 by Gdailey2112
i do believe that .010" was taken off the valve, so from .11mm clearance with a 2.00 shim, so i'm thinking this should put my shimming in the 2.35 or 2.40 range?
1982 KZ1100D1
06 Oct 2022 05:16 #875152 by Jeff.Saunders
Replied by Jeff.Saunders on topic am I correct, the valve doesn't rotate generally?
The cam lobe is not centered on the bucket/shim, so there is a little rotational force going on.  The offset is to spread the wear on the shim/bucket.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
The following user(s) said Thank You: slmjim+Z1BEBE, SWest, Scirocco, Gdailey2112
