am I correct, the valve doesn't rotate generally?
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
Re: am I correct, the valve doesn't rotate generally?
06 Oct 2022 11:39
#875176
right on Jeff!! that is what i'm lookin for.
great responses from all, thank you
1982 KZ1100D1
  • DFIGPZ
  • DFIGPZ's Avatar
06 Oct 2022 16:08 - 08 Oct 2022 12:39
#875186
The cam lobe is not centered on the bucket/shim, so there is a little rotational force going on.  The offset is to spread the wear on the shim/bucket.]
Jeff
 Is Correct cam is not centered on valve so some rotation should be expected
1984 750 Turbo
Last edit: 08 Oct 2022 12:39 by KZQ.
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
09 Oct 2022 14:37
#875298
just something that had me wondering
to me, you fellas are some of the most absolutely knowledgeable gurus, i'm jvery grateful
1982 KZ1100D1
