Spark plug color
- gordone
Re: Spark plug color
05 Aug 2022 14:36
Have you installed air corrected jets?
by doing that you can use orginal jetting and needle height, only adjust for det 4 to 1 Exhaust.
Project:
Project:
- Maxbou92
05 Aug 2022 15:06
I cannot find anywhere the air corrected jet (62). I have 4 pod, 4-1 stock exhaust with open slip on, small porting, 0.06 milled head, 0.5 oversize. So my set up for now is ; 125 to 130 main jet, pilot at 2 1/4 turns, Im waiting 40 pilot jet?! With 2 of 0.5mm shims needle. Planning to renove one shim, it makes some Burp at low rpm in each gear!! But at 3500-6000 it sounds and ride very good!! I dont push it more for my new engine !!!
Kz750e 1980
- zed1015
07 Aug 2022 04:44With pods and air corrector jets you still need to increase the main jet size regardless of exhaust fitted.Have you installed air corrected jets?
All other settings remain stock .
- Maxbou92
07 Aug 2022 04:50
All right, so now I have 130 installed instead 125 and 1mm needles shim. What are you thinking about
Kz750e 1980
07 Aug 2022 07:37
- Maxbou92
07 Aug 2022 07:49
Thank you, but I dont think these jet works for the Keihin Cv34. I haven’t any jet that looks like these jet?!
Kz750e 1980
